Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
The coffee comes out bitter on my Delonghi Magnifica
I think this is because the water is heating up past 175 degrees. Have a fully automatic Jura Capresso at the office and same beans taste super. Is there a way to get my DeLonghi's water temperature set to 175?
  • Peter Vessenes Jul 13, 2010
    I think this is because the water is heating up past 175 degrees. Have a fully automatic Jura Capresso at the office and same beans taste super. Is there a way to get my DeLonghi's water temperature set to 175? I keep the inside unit clean and service it with the liquid decalcifier every 300 cups. Additionally, I only use RO UV water in both systems, and the Delonghi still comes out bitter. If I need to regulate the temperature of the water, how (or where) can I get this done?
    Thanks!
  • Peter Vessenes Jul 18, 2010
    Solution implemented, case closed, great result! Thanks to everyone.
  • 1,555 Answers
Your machine is fully automatic and the manufacturer has left you with only two temperature settings. The logic behind giving two temperature settings is that few like it hot and few like mild. Hence, If you wish to lower down your temperature and your current temperature is high or vice versa can be done.
Temperature control! For that extra hot Cappuccino or Latte move the frothXpress Plus dial from the "-" settings towards the "+" settings to increase the temperature.
In any case if this does not works with your machine Kindly let me know your model number so that I can provide you with accurate solution.
Posted on Jul 13, 2010
  • 2 more comments
    Thanks for your suggestion. I am out of town and don't have access to the Delonghi until this weekend, but will try it then and let you know.
  • Aruna Singh
    Aruna Singh Jul 14, 2010
    Let me know when you have access to the machine. Then we can proceed with the solution.
  • Peter Vessenes Jul 14, 2010
    Will do.
    Thanks!
    Just got back home. Went to the menu to see that someone (housekeeper?) had turned the temp up to Extra Hot. I dialed it down via the menu and all is well. Thanks for your (and everyone's) great help.
  • 2,272 Answers
Coffee tastes bitter due to dusty got collected in the interior.Clean the filter as well as the interior of the machine. Then check out. First thing to do is clean your coffee maker, people don’t realize that this is necessary. Pick up a coffee maker cleaner or us something like CLR deluded in lots of water.
Next, if the occasional coffee is bitter the trick to fixing it is a pinch of salt. By pinch I mean just a few grains. The sodium reacts with the acids in the coffee and removes the bitter taste.
clean your coffee maker with white vinegar and water. Run it through a few times then run clear water tho a few times.
But still if the coffee taste is similar and no change then yes its the problem of warming plate in the coffee maker.Its getting overheated and coffee is getting overheated from what is not required and the taste changes.The heater unit needs to be checked.If the element is short it needs to be replaced.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 12, 2010
  • 1 more comment
  • Peter Vessenes Jul 12, 2010
    Thanks. I am pretty anal about keeping the machine clean both physically in the internal parts I can reach, and with the regular cleaning liquid the machine requests after about 300 brews. I will try the salt and vinegar steps when I get back from out of town, but am still skeptical, as the Jura Capresso gets the same care and the coffee comes out perfectly. If the heater is malfunction, where should I get it serviced? It was originally purchased at Starbucks. Thanks! This was a super fast response.
    One more comment/question. Since this is a fully automatic coffee maker, it does not allow me to run vinegar/water, or just water through the coffee maker without grinding and compressing beans. How do you suggest I run the vinegar solution through the machine? Should I just brew beans with the vinegar?
  • raj somaiya
    raj somaiya Jul 18, 2010
    yes that is the only option in automatic coffee machines to run vinegar.
    thanks for keeping updated with your query.
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Ena9 coffee comes out is bitter
The most common cause of bitter coffee is that the water is too hot. And the most common cause of too hot water is too much pressure in the boiler. So, the first thing to look at is the pressurestat of the machine, it should be accessable and adjustable. 1.5 bar is often the maximum pressure for good coffee (don't confuse it with the 11 bar pressure in the grouphead when brewing).
Jul 28, 2014 | Capresso Jura-Silver/ Black ENA 9 One...
I want to get more water in my coffee when using a delonghi 3200 automatic coffee machine
as water comes out push and hold the selected button until it fills wer you want it................... 07779933829 for services
Oct 22, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have descaled and cleaned all parts of my delonghi Magnifica machine. The coffe beans are high quality and I have tried all levels of grinds. The coffee is extremely bitter and I can't think of any other...
Sorry to read about your problem, I hope this helps you out.
run some more fresh water thru the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Brew temperature is too low
I think you ment kaffeestudio.de and their webshop redirects to
http://www.juraprofi.de/Service-Anleitungen:_:70.html
Eg http://www.juraprofi.de/anleitungen/E-Serie_Innen.pdf
May 31, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Water not pumping
Typically this is caused by the heating/water unit inside the machine drying out. Not being totally familiar with your machine let me offer this suggestion: if you have a "hot water" function that allows you to run hot water out of the machine use it to allow water to get back into the heating unit. Once water flows through without interruption you should be able to brew coffee again. I know this is the case with Jura machines and the problem you described is identical to what happens with those machines when the internal heated water tank runs dry.
Mar 30, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
2,424 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
