Question about Remington Electric Chain Saw
Switch problems reminton electric chain saw lnt-207628k
Have a dead spot in switch if you press to far on it it will stop at the right spot it will work is there a way to fix the switch or where can i get a new one
  • 8,404 Answers
You can get a switch special order from any Ace Hardware or other fine hardware retailer or chain saw/lawn mower repair shop or rental place or from a FixYa.com advertiser.
Posted on Jul 12, 2010
What kind of oil is used for a 12'' 115v elec chainsaw model lnt-2
Hi, any brand of bar and chain oil is fine. Hope this helps, regards Phil.
Jun 14, 2011 | Remington Electric Chain Saw
Need replacement chain for remington 14inch, EL-1 and remington LNT Limb N' Trim 8. Could you provide me with current replacement chain information for both?
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
May 09, 2011 | Remington Electric Chain Saw
Chain adjusting screw does not adjust--socket adjusting srew turns into is broken. Remington Type LNT-2, Model 100089-08.
you can get a manual for the 100089-08 at
http://www.desatech.com/chainsaws.htm
And also find a dealer that carries the part for adjusting the chain.
Let me know if you have any other questions. Thank.s
Apr 18, 2011 | Remington Electric Chain Saw
I have a reminton 14inc limb and trimb. What kind
Use regular bar and chain oil available from home centers, hardware stores, and saw dealers.
Jun 08, 2010 | Remington Electric Chain Saw
Repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington Garden
Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Oct 11, 2009 | Remington Electric Chain Saw
Where can I get parts for my remington limb n trim chain saw model # lnt-2, serial #037215
Your model is LNT-2 you can find an IPL here:
I recommend you print it. Click the part number you need. HTH
Lou
Sep 26, 2009 | Remington Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Looking for owners manual andoil cap for reminton chain saw es1514as
Here is a link to the owner's manual you requested... http://12.153.20.74/manuals/120877-01C.PDF . I suggest you contact the parts department at 800-446-1446 or online at www.masterparts.net , they should be able help you get the oil cap for your unit. Thank you
Apr 18, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
134 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
