Question about Epson Artisan 800 All-In-One InkJet Printer
Epson Artisan 800 continually indicating paper jam error--No jam.
I purchased an Epson Artisan 800 (2008) from Best Buy and after a couple of mouths of use the printer continually indicates a warning/error message upon startup. The message states "An error has occurred. Turn off the power. Check for and clear the paper jam. Reattach any parts you may have removed. Turn on the power. For details, see your documentation."
I have followed the directions and searched for a paper jam and have not found one, yet I keep receiving the same error message.
I realize this may be a common problem with the Artisan 800 series and appreciate any advice.
Yes, that fixed the problem on my Artisan 800! Thanks so much for the info about slipping the cr scale back onto the u-guide on the back of the print head carriage, Larry P and dabaker!
For those trying this, the u clip is upside down so, from the front of the printer, you move the CR scale ribbon down a little and in towards you gently, in from the back towards the lower part of the rear of the print head assembly, and it will slip in on the top part of the ribbon into the u shaped groove (which, to be technical, looks more like an n-shaped groove, an upside down u). If it is loose and not clipped in, the CR scale ribbon will bow out easily on both sides of the print head carraige when lightly pressed towards the back of the printer near either side of the print head. (As pointed out in the service manual, do not touch the ribbon with your fingers, particularly if they may be greasy/greasty/gritty; use a clean tool for this-I used a q-tip which worked well for both testing the tension and for pushing it down and back into the proper guide slot.) If the CR scale ribbon is clipped in properly to the print head (properly seated in the n-shaped slot), it will bow towards the back of printer easily ONLY on the side that your press it from (ie left or right) but not on the opposite side of the carriage; the opposite side will remain almost entirely flush to the rear of the print assembly. Remember to press gently; you do not want to stretch or damage this scale ribbon if you can help it. If you have a small dental mirror and good light, you will be able to see the n-shapped clip (it's plastic and black on my 800 clearly. If the ribbon is correctly seated, it will be in the slot at the top and free at the bottom. Because of the use of u-slot in the previous posts, I was confused as to where to fit this in but then figured, nothing to lose and yep, it's actually the n-shaped slot at the top.
Posted on Apr 09, 2016
5 Suggested Answers
  • 9 Answers
SOURCE: Epson 800 Artisan printer was
I cant take credit for this fix, but it worked on my Artisan 800 with the same error. My error occurred right after a paper jam where i had a tough time removing the paper.
"Open the printer. See a 1/4" grey plastic band that is attached to the
print head. This is the CR (carriage return) guide that tells the print
head exactly where it is. During a paper jam it is sometimes pulled out
of the slit on the head carrier that it has to be in to tell the print
head where it is on the carriage. Pull the print head out about half
way, and with a flashlight look behind the head carrier. You will see a
small plastic u-shaped piece. Make sure the CR ribbon is INSIDE the
slit, or u-shaped device. When this happens you will usually hear the
print head hitting the side of the printer twice while it tries to
determine its position. Be very careful not to damage the ribbon. It
will slip back into the slot quite easily"
My print head didnt want to pull out, so i took a small inspection mirror and had a look behind the print head. Sure enough the ribbon was outside of the sensor. I easily pushed down on the ribbon gently with my finger and pulled it towards me just a little bit and it popped back up into the slot. Closed the printer up and no more message.
Hope this helps some other poor soul.
Posted on Dec 25, 2012
SOURCE: i had to clear a paper jam in my Artisan 800
This problem is usually caused by the CR Scale forced out of it's **** by a paper jam. The CR scale is a 1/4" wide strip of grey plastic band that is visible when you open the printer. It is right above the serial number. Slide the head carrier to the left and look behind the head carrier. You will see a small U-shaped plastic piece. Make sure the CR scale is within the **** or u shape. Be very careful not to damage the CR scale as you slip it back it. When this scale is flipped out of the ****, the printer head slams into the right side of the printer on start up (twice) and produces the fatal error message, with the paper jam note.
Posted on Jun 03, 2011
sherlyn c
  • 134 Answers
SOURCE: trying to scan to email on Epson Artisan 800
If you are scanning wirelessly, you have to launch the epson scan software from your computer and scan to e-mail from there. You can scan using either professional or home mode.
Please take note that scanning from the printer only supports direct connection, which means you have to plug in the printer to your computer via a usb cable.
If you cannot launch epson scan, please let me know. And include the operating system that you are using too.
Posted on May 03, 2009
  • 3 Answers
SOURCE: epson artisan 800 will not print
please make show that ur connection to the printer is correct.mostly if u using usb cable.uninstall and reinstall ur printer drivers can solve the problem.
Posted on Apr 19, 2010
When doing two sided printing I always get a paper jam indication when none exists. Single sided is OK.
Likely a small peice of paper stuck in the rollers on the paper flipping side, or a bad sensor.
Dec 29, 2014 | Epson Artisan 837 All-in-one Wifi Inkjet...
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Paper jam was cleared and all parts replaced however it still indicates error problem about clearing paper jam.
did the paper perhaps tear leaving behind small parts ?
are there other areas that other pieces of paper could be ?
The display would tell you which key to press if there was a need:
-select- or a symbol key of some kind.
At the very-least, you should be able to turn-off, then back-on the printer which would perform the same function.
Tallon41
Sep 16, 2012 | Epson Artisan 800 All-In-One InkJet...
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
I had to clear a paper jam in my Artisan 800 printer. i followed the instructions and cleared the paper, but when i turned the printer on the the screen continued to flash and indicate error. the paper has...
Mar 24, 2010 | Epson Artisan 800 All-In-One InkJet...
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
My Artisan 800 is having continuous paper jams, and now I think something's wrong with the nozzle or something, it seems to be having a hard time moving across and is making a crunching noise. I tried the...
please you r printer driver cd original is use. first old progreem printer driver is instol and restart pc and 10 minut wait and instoll aoriginal driver. and your printer is so the paper tray in fixed. second carteries is out of printer and so in fixed paper. and add a cartries and start printer and aply paper and aply print.
Sep 24, 2009 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 All-In-One InkJet Printer Logo
1,911 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
