Question about Xerox DocuColor 12 Printer
PAPER CREASES AS IT EXITS THE PRINTER
Can anyone help me my DC12 creases the paper, basic white copier, a friend had a simular problem however his machine is on a service warranty and the service engineer fixed the problem anyone know how ?
  • 62 Answers
It actually needs an oiler, and IS expensive. I do this on a daily basis. Other fuser parts may be affexted by the contaminated oiler
Posted on Nov 19, 2008
  • 7 Answers
Try a new unopened stack of paper preferably 90gsm good quality , if that fails, its a fuser problem which means it will need a presure and/or heat roller
Posted on Nov 05, 2008
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
No you will have to get a techie out - the plastic gears is not aligned - seems to be due to wear and tear. (this shoud be re-fastened or replaced. (not an expensive exercise)
Posted on Apr 20, 2008
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
How do I fix creases in the paper being printed
Sounds like your fuser needs some maintenance. These are wear and tear machines.
If you're in Houston we can get you fixed up. Skelton is the best copier service company in Houston. Skelton Business Equipment Houston Copiers
Jul 14, 2014 | Sharp Office Equipment & Supplies
Paper creases
I have the same problem with my printer.??????????
Feb 18, 2014 | Samsung SCX Office Equipment & Supplies
The printer creases the paper top left hand corner
hi just check the inside one paper gear will be if it is creases measn that is problem
Dec 16, 2010 | HP LaserJet 1300n Printer
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
May 28, 2010 | Kyocera FS-3900 DTN MONO LASER PRINTER
My Hl 4070Dw laser color printer is makeing creases
Check that u have no paper stuck under the platen
get a blank sheet and feed it through manually
this will clear any blockages or residue one the rollers
if you still get a problem , the printer needs to be sent back to the manufactur
Nov 13, 2009 | Office Equipment & Supplies
Slight crinkling of paper
You will need to replace the fixing film in the fuser unit. Unless you have done this before, I recommend having it serviced by a qualified service rep.
Sep 01, 2009 | Canon PC-920 Black and White Copier
Creasing and jaming 60 gram paper
1. change the paper type setting to the lightest media setting you can find. this will be found in the paper handling menu. make sure that you do this on every tray that you will run the lighter media through. the reason for this change is to adjust the timing and temperature ranges in the machine.
2. if that doesn't help then try printing simplex (one sided) to see if the jamming is still in the same place. if the jam persists then you have a fuser problem, if not then your issue is in the duplex ***'y.
Having said all of this, blow the machine out with canned air before any of this with the toner cartridge removed. the reason for this is not just the obvious cleaning, but to find broken sensor flags. they will look like flat plastic pieces that will be white or gray on one end. if you find one of these flying out of your machine then there is your problem. Good Luck!
Sep 15, 2008 | HP LaserJet 2420 Printer
Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Dec 05, 2007 | Samsung CLP 300 Laser Printer
Xerox DocuColor 12 Printer Logo
136 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
