Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Red light on in freezer
Freezer is warming up. rubber insulation is hot
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerred light on in freezer - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
LG side by side Model LSC 26905
Insulation does not melt - gaskets may be affected by hot temps.
Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
Jul 29, 2016 | LG LSC26905TT Side by Side Refrigerator
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
Refrigerator cools poorly but freezer is OK, what's the solution?
There are various reasons which can cause this. They are
  1. Interior sweating.
  2. Bad door seals.
  3. Excessive door openings during hot humid weather.
  4. Storage of excessive uncovered liquids especially if they are inserted into refrigerator while warm.
  5. Void in insulation.
  6. Overcharged.
  7. Bad door seals.
  8. Condenser fan not running.
Jun 21, 2010 | AEG SK71840-4i Top Freezer Refrigerator
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer is cold and refrig is not cooling
This is a very common problem. Ususally it is because of a problem with your defrost, either the coil of the timer/advanced defrost board, or fan failure. You can get a more detailed explanation of your problem by reading this tip about your problem.
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Jan 24, 2010 | Refrigerators
The red lens seems stuck on the brake light next to the roof line. Is it glued on?
Nope. Just a really good seal with the rubber seal beneath it...Try warming it with a hairdryer..but not TOO hot :) Hope I could help. Mike
Dec 01, 2009 | 2005 Toyota Highlander
I see a red light like something is red hot behind the back panel in the freezer. I removed the panel and I see a coil with 2 clear tubes that have some type of spiral metal inside. There is 1 midways of...
Those are the defrost heaters and glows red hot when defrost action is active. It should turn off when defrosting is complete or when the temperature is about 46 degrees Fahrenheit. If it does not turn off, the freezer will not function properly or it will be warm than normal. Have the defrost sensor assembly checked by a qualified technician.
Nov 06, 2009 | GE GSH25JFR Side by Side Refrigerator
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Strip between freezer & fridge
light falshing is normal, the strip between being hot is not though, remove the kickplate from under refrig and vaccuum the coils, pull unit out and clean behind, while there make sure that the fan adjacent to compressor is running(when compreessor is on). clogged condensor =hot mullion stip. not a major problem
Mar 02, 2008 | Kenmore 51252 / 51254 / 51259
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
