Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
Looking for shift sell for Flotec: FP5162
  • 760 Answers
I've never heard of a shift sell for a flotec water pump. That is if you are looking for a part for a Flotec sprinkler pump. Maybe you're looking for a shaft seal.If you need parts or a manual you can look at www.flotecpumps.com The flotec part number for the mechanical seal and gasket kit is:5PP5000. You can search their web site for local suppliers, I'd call first to see if they'd have part in stock. Follow directions when installing. Do not use oil or grease to lube new seal. Liquid dishwashing soap is best.
Posted on Jul 12, 2010
Flotec FP5162 ressure fluctuates
it sounds like pressure drop from worn o-rings, diaphragm or impeller as you say. Do the overhaul. Remember to take pictures as you strip
Apr 07, 2013 | Flotec Plumbing
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
I need an instruction manual for a FloTec sprinkler pump model #FP5162
Here is a link to the manual for: FP5162-08, FP5172-08, FP5182-08 http://www.flotecpump.com/resources/images/527.pdf
Jun 11, 2011 | Computers & Internet
I have a flotec 1 hp pump model number fp5162-08 hooked up to a 30-50 blader tank suppling two hose bibbs suppling water to two hoses with manuel sprinkler heads. The pump will not pump more than 34psi to...
I am going to take a stab at this it sounds like the bladder has gone bad it the expantion tank. Try letting some air out of the bladder tank and see if you get any water if you do then the bladder has gone bad the tank will need replaced. After the replacement turn the limit switch back to normal settings. You can also tap on the tank to see if it is full of water.
Feb 09, 2011 | Flotec Plumbing
My flotec pressure tank seems to be waterlogged, how do I recharge it?
I don't know your model. Generally, a newer pressure tank has a flexible bladder that separates the water from the air charge. If you have water on the top of your tank, the bladder has broken. It seems that Flotec tanks have replaceable bladders. Flotec Pressure Tanks
That is a link to a company that sells parts for theses tanks.
Gary.
Dec 04, 2010 | Electrical Supplies
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
What is the proper 115 volt wire connections for an FP5162-01
on the pressure switch just make sure the two whites are on one side and the two blacks are on the other side.Line is the house power and the load goes on the other.
Apr 30, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a fp5162-08 sprinkler pump that keeps sparking when the system comes on
A flash from the motors internal starting mechanism is normal; a spark shooting out through the endbell is not. If it is that severe, the motor is starting to fail and you should have it serviced at the end of the season assuming it lasts that long.
Jul 09, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
185 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
