I have a usb file transfer cable, and External Sata, and I would like to transfer all the information on my existing 60Gig into my new 500Gig internal drive. If I wanted to acquire my Desktop shortcuts, and Favorite how could I do it?
  • manga_03jada Jul 12, 2010
    Yah See? Not only are you an animae fan like me.... But you are also a regular brainiac..lolololo Thnx Money
  • 6,487 Answers
If you want to transfer first all files from the 60 to the 500 GB hard drive you can do that by putting the 2 hard drive inside your desktop computer so they will be a separate unit and then you can copy all files from the 60 to the 500 drive or you can also connect the 60 to the external hard drive enclosure and then use it as a USB drive then transfer all files from it to the 500 drive.
Then if you want to access those files instantly , you can right click the folder or the drive and click create shortcut and then paste that shortcut where you want to put it for easy access.
Posted on Jul 12, 2010
  • Mark Gil
    Mark Gil Jul 12, 2010
    Yup anime fan here also, Anime like Naruto, One piece , Hunter X hunter and many more.
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I want to connect this hard drive with other computer. What kind of cable shoud be use for data transfer?
Much better if you buy a usb to sata adaptor, all you have to do is plug the usb adaptor from sata hard disk drive to usb port. It will detect as a removable drive and it is very easy to transfer file. It will serve as a external hard drive. Have a nice day!
Jan 03, 2011 | NEC (OP-220-62006) 1.35 GB Hard Drive
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
USB PORT ON EXTERNAL HARD DRIVE IS LOOSE AND WON'T BOOT UP
buy a usb to sata or ata ide cable. then remove the drive rom its housing. Use an old psu to power the drive and plug the usb-sata cable into drive and pc, transfer all the filees to your pc. this will work indefinately so you dont even need to buy a new external harddrive. More permanent solution , install the hdd in your pc as a secondary drive.
Mar 19, 2010 | Computers & Internet
I need to transfer data from an old and sickly Dell Insiron 8100 to a new 2010 external hard drive....no conforming ports....pls advise what I need to purchase...cable?....for transfer ...and either...
The first thing I would do is pull the hard drive from the sick Inspiron. Now get yourself an IDE/SATA to USB adapter from a computer retailer or on Ebay, they cost about 20 bucks. Attach the HDD from the Inspiron to the adapter and attach the usb side of the cable to a good computer. The computer will now read this drive as an external and allow to access any and all files. Just make sure that before you remove the HDD from the Inspiron, you remove any passwords on the computer that might limit your access to files. Also on the good computer go to control panel > Folder Options. Click on the boxes to allow viewing of system files etc. just for a little while, during the files copy. Make a folder on your desktop and name it whatever you want. Now go through the HDD from the Inspiron and copy any and all files to that folder. When you have finished, attach your new external. Now just copy the files from the folder on the desktop to the new external drive and there you go. These adapters are the only true way to be able to pull this off. Good luck
Jan 28, 2010 | Dell (0K724) for Inspiron 8100 40 GB Hard...
How to get information from an old XP computer to a new Windows 7 computer
Copy the files you want from the old PC to some kind of removable media, i.e. CD, flash drive, etc. and copy them to the new one from the media you have chosen.
Dec 31, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Stuck in safe mode and can't get to reboot
either the hard drive has failed or you are experiencing software corruption of your windows files.run the recovery or if you need information from that drive get a new hard drive install it run the recovery and use an external usb ide-sata converter to transfer your files
Nov 04, 2009 | Toshiba Satellite M35X-S349 Notebook
Read only on a mac
http://www.seagate.com/staticfiles/support/downloads/firmware http://atulchitnis.net/files/seagate.pdf
Apr 18, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Disk boot failure
Technically you can copy all the data from one to another hdd but not the operating system
You have to install your operating system (windows, linux or MAC) on your new 500gig hdd and then copy your data from 60gig hdd.
Regards
Jan 22, 2009 | Avanquest DISK COPY & CLEAN (WIN...
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
