Question about Vizio VW32L 32 in. LCD HDTV
The volume fluctuates on it's own?!
Sound issues
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
Why does the volume on my Vizio tv fluctuate, and what can I do to fix it?
Doesn't work for me, turning off all sound enhancements does nothing, come still fluctuates, I feel ripped off, what a huge let down.
Sep 13, 2011 | Vizio VF550M 55 in. LCD HDTV
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
Problem with Midiland S2 4030 powered speakers
Mike, I have the exact same issue. Did you have any luck resolving this?
Thanks,
Jim
Jan 11, 2010 | MidiLand S2 4030 Computer Speakers
Sound volume fluctuates
sounnd like your power supply
check you cap,s in power boulg cap.s
Aug 12, 2009 | Polaroid FLM-2632 Television
gah im having same problem with my creative 5.1s... took it apart and used contact cleaner on every bit of soldering i could see, and checked the wire... still no luck
Sep 27, 2008 | Logitech X-540 Computer Speakers
Got t7900`
I have had that problem with a T7700/T7900 speaker system.
Disconnect the remote control from the subwoofer. Then what you need to do is unscrew the remote volume/bass control unit (4 little screws). Swab the contacts on the volume dial with a cotton bud (q tip) denaturated alcohol or even perfume will work. Make sure you do it several times until all the slight dirt that is causing the volume fluctuation/spikes to happen. Also remove any remnants of cotton that might get stuck.Now you'll have it working as new as long do not cause any other damage to the unit.
Cheers,
Daniel
Jul 02, 2008 | Creative Labs Inspire T7900 Computer...
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Vizio VW32L 32 in. LCD HDTV Logo
692 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
