Question about Arris SURFboard SB4100 Modem
My Device is not working it only haves 3 lights and all the lights are not all light up i need help
And
Posted on Aug 31, 2010
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
Tonight I went to turn on the light and i felt a static shock, then the light just started blinking and the fan would not respond. The light on the switch is just going up and down? Is this a hazard? What...
You posted under Maestro fan-light dimer, but don't say what type of wall device this is.
It sounds like electronic switch.
1) Surge might have burned out device electronics.
Turn off circuit breaker and see if device resets itself.
2) Lutron has tech support number
1.888.LUTRON1
(588-7661)
8-8 eastern standard time
3) Help identifying product for ordering online replacement if needed:
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroIRDimmer/Pages/Models.aspx
4) Add a comment for more free help.
5) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
I lost the codes for my reomote control i need to program my remote to my television
Hi! Try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
try searching for your codes by following the steps below.
I hope this helps.
Oct 12, 2010 | Universal Remote Control GE174Universal...
I have NOKIA 6233 HAND SET ,its key pad light is not working,
If the key pad light is not working the first thing you do is restart the device.
After restarting the device check the light and power settings it might be a sort of power saving mode.
If after checking the setting still nothing then restore the device factory settings to do this you need the device lock code.
If the light still doesn't come on then refer it to an expert for a closer look.
Hope this is helpful
Jul 03, 2010 | Nokia 6233 Cellular Phone
I need codes for GE Universal Remote 24944 RM84914 by Jasco Products Company
Try these steps... I hope this helps..
Jun 08, 2010 | Universal Remote Control GE174Universal...
My list of codes for my remote is missing, I need to program my remote. I need a code for my Tobisha television, please can you help me? I have a unervisal remote control.
try these steps... Hope it helps..
Jun 07, 2010 | Universal Remote Control GE174Universal...
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
I need codes
specific device.
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn of I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 26, 2009 | RCA DIRECTV Satellite Remote Control
Need to program a ge universal remote control to operate a Magnavox Total Control System TV
here is the 3 digit codes ive found to try 586, 651, 720, 666, 731, 800
MAGNAVOX ............ 0062 0004 0009 for digit codes
........................... 0456 0183 0226 0288
........................... 0008 0068 0075 0141
Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed,
try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
Jun 21, 2008 | Televison & Video
Need code for remote control
Code Search Method: Turn on the device you wish to program. Press and hold CODE SEARCH until the indicator light lights, then release. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit. Press and release off-on until your device turns off. You may have to press off-on up to 200 times. When your device turns off, press the ENTER button and the indicator light will go off. Code Entry Method: Manually turn on the device you want to program. Find the code for your device in the code list. Press and hold the CODE SEARCH button until the indicator light lights, then release. Press and release the device you want to program, the indicator light will blink then remain lit. Enter your code using the number buttons.After your code is entered the indicator light will turn off. Aim the remote at your device and press the off-on button. The device should turn off. APEX CODES: 006,014,033,035,036,039,041,152,247,172, 173
Sep 15, 2007 | Televison & Video
Arris SURFboard SB4100 Modem Logo
87 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
