Question about Schwinn Wide Ride Pedal
Diamondback 1100es stepper has a squeak near the petal I do not know how to get rid of. Please help.
  • phx2azo Jul 12, 2010
    I found the problem. Thanks!
    President:
  • Schwinn Master
  • 832 Answers
Penetrating oil does the job apply on all bushing let it sit then try the unit if you need to apply a bit more then do so.
Posted on Jul 17, 2010
How to reassemble diamondback outlook forks
Hi, Hugh for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Diamondback, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.diamondback.com/Data/Sites/12/media/support-owners-manuals/2012_om_diamondback.pdf
Fix Five Common Repairs
Diamondback Tech Fork Sag setup
Replacing Forks Shocks On Mountain Bike
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 20, 2016 | Motorcycles
My Chevy venture 2001 was squeaking when l made right turns so I lubed it up now it stop squeaking but makes a popping noise instead help please
Bad ball joint. Lube got rid of squeak but now the worn part pops as you turn. Replace both sides to be safe.
Mar 29, 2015 | 2001 Chevrolet Venture
I have a 2001 Dodge Intrepid and recently replaced the rear break pads. I've noticed that randomly; while, driving and pressing on the break petal, it sinks in slowly. What can I do to fix the problem?...
Check to make sure that you put brake grease on the back of the pad where it meets the caliper. Also, for the brake petal slowly sinking, this is most likely caused from air in the brake line. Make sure you bleed the brake lines and check for any possible leaks.
Oct 07, 2013 | 2001 Dodge Intrepid
Just changed all brake pads and rotors on 2004 Buick Lesabre. There is a noice like a brake pad noise at partial pressing of brake petal. Is worse after traveling about 10 to 15 minutes
If it's just a slight squeak and then it goes away then it's probably brake dust. Some aftermarket brake pads will still squeak depending on what pads you got. It's a good idea to go with ceramic pads that have a cut down the center of the pad and the ends are chamfered. This will help disperse the brake dust and minimize any squeaking.
~Brandon
May 27, 2011 | 2004 Buick LeSabre
My 2003 chevy tahoe dashboard gauges stopped working, i don't know which fuses to check out. they would go out sometimes and then go back on when i restarted the car up. please help.
The dash cluster is know for two different problems.
If individual gauges bounced erratically and then quit, the little stepper motors that run them are bad. Upgrades are available from eBay, but you need PC soldering experience to change them out. An internet search will show allot of people who will rebuild the cluster for you.
If the entire cluster died all at once, the most common issue is bad solder joints near where the plug attaches to the board. This is an easier fix than the stepper motors, but still you need to be handy with a soldering iron!
Nov 30, 2010 | 2003 Chevrolet Tahoe
I have a diamondback 1100 stair stepper, it won't "power up". the control panel won't turn on and no resistence
check your batteries and work on it without power about 30 mins they will re-charge
Feb 27, 2010 | Exercise & Fitness
I have a Diamondback 1100 ES stepper which recently started operating incorrectly. It appears that the magnetic flywheel is not exerting any resistance no matter what setting I plug in. Initially when I...
I've had this problem years ago. If I remember, the flywheel pickup sensor on the left side of the flywheel is slightly misaligned. If you tweek it it should solve the problem.
Jun 06, 2009 | Exercise & Fitness
Have squeak in front seat of 2003 toyota 4runner.
needs updated seat track from toyota. power seats only.
May 14, 2009 | 2003 Toyota 4Runner
Schwinn Wide Ride Pedal  Logo
322 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
