Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
Starter keeps flicking
I spilled coffee in to the controls for the on/off panel and the starter won'tr start flicking
    President:
  • 1,891 Answers
Dry the control with a hair dryer . and if that does not work replace the sw assemble . most of these come as a set .. mm
Posted on Jul 16, 2010
Model # RY 160LXTS sometime the broil come on by it self, causing the smoke alarm to goes off, what can I do to fix this problem, the range is 2 1/2 years old
if this is the model with the touch control buttons on front , ive seen a stove top spill that got down inside there cause some missoperation ,id start to look there for a reason , then id move on to replacing the control panel and last the logic board (its on back of front panel ) but I will say id unplug it till I resolved this problem if it turns itself on and your not home ,what could happen !!!!
Apr 09, 2016 | Whirlpool 4.5 cu. ft. Electric SlideIn...
1992 glass top gas cooker ingitors keep clicking just out of the blue. We realize there is no gas being delivered until the knobs are on but we have to unplugg the cord from the wall to keep them from...
sounds like your spark module is being grounded out could be from something you spilled on the cooktop or it is just gone bad. if it is water it could take a week or so to dry out then problem will go away. have you spilled anything latley?
Sep 20, 2009 | Cooktops
Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Jun 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
Apr 23, 2009 | Amana AKS3040 Gas Cooktop
Regular spill stain problems
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 13, 2007 | Maytag MEC5430 Electric Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Gaggenau clicking
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
Jul 27, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
