Question about Ecg Medical
Kenz ecg 107 doens read leads?????
Kenz ecg 107 doens read leads what could cause this ?????
the cable is fine, i just cheked and tested in aother ecg, so what soulb be wrong whit this equipment
4 Suggested Answers
  • 157 Answers
SOURCE: Omron Portable Ecg Ekg accuracy problem
Hello Josh. You will need a EKG simulator. I suggest you contact your local community (junior) college electronics class or a local Bio Medical services in your local hospital. When locating one kindly walk in and ask very nicely with the portable in hand if you my perform a operational test for you on benefit.
Posted on Sep 19, 2008
  • 4 Answers
SOURCE: MALFUNCTIONING LEAD ON ECG MACHINE
U may have problem with thorax electrode.
Posted on Apr 15, 2009
  • 71 Answers
SOURCE: how do u service an ecg cable and test its
I usually just jiggle the ekg lead wires around while hooked up to a simulator. If you don't do it this way you might test it and have it appear to be working but than turn into an intermittent problem. If you have more questions on this, please let me know.
wats@mesasales.com. www.overstockme.com. Jeff Watson
Posted on Jan 01, 2010
I have leads on patient and machine says leads off. everything is hooked up, why won't it give me a reading?
Any one of the lead is broken. you have to replace the ecg lead.
All the ecg machines have self diagnosing before its acquire the signals from the patient to print signal. while performing this function the machine detects all the signals from all the leads are prompt or not , if any one of the lead is missing it will not go further and will indicate check cable.
Electronics Equipment Repair Center
Oct 02, 2014 | Medical
With leads hook correctly machine contuines to flat line
Check your RL (green) lead or trunk cable.
Right leg is the ground so (if it's bad) you won't get a QRS complex.
Jan 30, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
When we connect leads to patient no thing out in ecg paper however before conncting this leads there is noise see in screen
hi,
check the patient cable. if there is any break ( inside ) in the lead it will this problem can occur. also check is the patient cable properly inserted in the socket or not.
if any lead is broken the ecg will not print, also show interference in the display.
try to change the patient cable.
ok
Jan 18, 2011 | Zoll AED Plus wECG Package Graphical...
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
The print for the reading is dark and the lines are all over the place. Mac1200 Thanks, Draya
If the ecg waveforms are all over the place you are probally recieving electrical interferance. If that happens when nobody is connected try adjusting the filters and see if it makes a diffrence. If it does not make a diffrence it might be the patient cable or leads.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jul 15, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
How do u service an ecg cable and test its resistance???
Sep 28, 2009 | Philips Medical
Apr 09, 2009 | Invacare Medical
I have the Welch Allyn PCR 100 and have never been able to get it to produce an ekg even though I returned it and they had it working, when I hook it up it just doesn't work. Any suggestions?
Could be bad\expired electrodes, mislabeled lead wires and the patient cable is loose. Also, if one lead is intermittently working it may not show any leads on the report because that one lead is bad. If it is an intermittent problem it could work just fine for somebody else and not you. I can work on this for you if you need more help.
Mar 26, 2009 | Welch Allyn Pcr-100i Pc-based Resting Ecg...
Medical Logo
127 people viewed this question
Top Ecg Medical Experts
Rhonda Webster
Rhonda Webster
Thomas Stromgren
Thomas Stromgren
Are you an Ecg Medical Expert? Answer questions, earn points and help others
