Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Refrigerator not getting cold enough. I adj the temp setting and waited about 4-5 hrs and dide not notice a difference. I had noticed a little water and noises and this eventually happened.
  • kieutrang75 Jul 24, 2010
    Hi, the summer is so hot in GA, and I have 2 little kids. My refridge is not cold anymore. I bought this 4 yrs ago and lost its instuction booklet. Now I can not find my model with Hotpoint (HSM25GFTASA) side by side. Please help me to fix it. I took the all foods out, cleaned the dust behind the refridge, pulled the cord out and clean inside. I wait for the water melt completely before plug it in again. Is there any trouble shoot to make it cold as normal before. Thank you so much. My email: nguyentrang50@hotmail.com.
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerREFRIGERATOR NOT GETTING COLD - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning RefrigeraREFRIGERATOR NOT GETTING COLD - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Temperature controller of the LG GLD 292 RPJL is off, what can I do?
MAY HAVE a bad cold control thermostat, however the setting should never both be set to high. 5 may be a bit to high they should be set at medium. otherwise I suspect u may have a bad control board issue not communicating with the cold control all can be checked with a multi meter
Mar 13, 2015 | LG Refrigerators
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our 3 months old refrigrator will get so cols that freezes food products.
There are actually 2 cold controls on refrigerator-freezers. The main control is within the refrigerator cavity, the other is located in the freezer cavity. The one in the freezer is usually only a cold air deflector. It takes the cold air that is produced and divides it proportionally between the freezer and refrigerator sides. Set the control in the refrigerator to about mid-range. Set the control in the freezer to mid range. That is your starting point. If the freezer is not cold enough, adjust the freezer control. If the refrigerator s not cold enough, adjust the fridge control. After any adjustments, you MUST wait at least 24 hours for the temp to equalize before making any more adjustments. It may take a week to get it set right. This is true for all refrigerator-freezer combinations. Be patient.
Oct 09, 2010 | KitchenAid Refrigerators
Settings
The freezer should be set at 4 or 5 to start. If that is not cold enough then move the temp knob to 6 or 7 to get it colder. the higher the # the colder it will get. Onse you set the new temp it will take around 4 hrs to get to the new setting.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
WE BOUGHT A 25 CUBIC AMANA REFIGERATOR AND WOULD LIKE TO KNOW WHAT TEMPERATURE SHOULD THE REFIGERATOR BE AT. OURS WAS SET AT 4 BY THE INSTALLER, BUT I HAVE NOTICED THAT OUR MILK IS SPOILING BEFORE THE...
Depending on which is the lower temp settting I would say you are correct I would set it to a higher no.Assuming the higher no.is a colder setting and not vice versa try 5 for a day or so and test the milk by drinking it and see if it is much colder but not freezing.if npot cold enough go to 6
Mar 07, 2010 | Refrigerators
Have a 4 yr old Kenmore model #25374879401 stopped cooling/quiet
you are waisting you money by buying thermostart. you have your gas chockage.... and this can only be resolved by a technician only
Jun 03, 2009 | Refrigerators
Refrigerator and freezer not cold enough
Can you find the make and model numbers for me. The model is usually located inside the fresh food section door near floor. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Refrigerators
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
100 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
