Question about HP Computers & Internet
My PC has gotten slower and slower and I can't fix it. I have used all the troubleshooters on my PC and downloaded Uniblue registry booster, to no avail. What else can I do?
  • 808 Answers
Try reg in out it will solve ur problem
Posted on Sep 09, 2010
    Sniper:
  • 72 Answers
Try the following
1. click on start -> then choose run -> in the run window type temp and hit enter. A new window would come up. Select everything on the window and delete it.
2. click on start -> then choose run -> in the run window type %temp% and hit enter. A new window would come up. Select everything on the window and delete it.
3. click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select everything on the window and delete it.
4. Restart the machine.
I am sure that this would resolve the issue. In case it does not try this
click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select the tab Startup, and click the button Disable all. Click apply and then OK and restart your coputer.
This should help. in case not click start -> Accessiories -> system tools -> Disk Defagment
In case that also does not works, scan your computer for some viruses.
This should help
Posted on Jul 12, 2010
  • 596 Answers
Couple of things to try - Check your memory. If you can add more, do so. This will show great improvement. Delete your Internet temp files. (The easy way - My Computer>right click on 'C' drive> Properies>Clean Up Drive. I would select all blocks and select remove.) You can also delete apps that you don't use anymore. This can be done by going into the control panel and select Add/Remove Prorams. Scroll through and delete apps you no longer use.
Good Luck
C2S
Where can i get Uniblue registry booster 2012
Go online and Type: Uniblue registry booster 2012
May 02, 2012 | Computers & Internet
Windows code 28
this is a registry problem
you may need to buy a regfix download to clean in fix ur pc or laptop
and yes if u do not have one on your system now that u can use u need to buy one .
CODE28 = slow running // crashing // freezing // BLUE SCREEN !!!!!!!
i use Uniblue PowerSuite 2011 this one have all 3 ( registry booster )
( speedupmypc)
www.uniblue.com ( driverscanner)
you dont have to use this one but it works for me .
its a lot out there
good luck
0
Oct 08, 2011 | Computers & Internet
I typed the serial number (RB-0HR4N7-NWYFRE-WGVT8T-P2GVR7-T50U22) for Uniblue Registry Booster and it didn't work for me. It says that the serial number is invalid. While the same serial number worked...
not need to use uniblue registry booster because one of a better software available for complete system tweak. you can download this software and cd key from torrentz.eu soft ware name is " utility 2011 ". enjoy your computer performance thank you.
Sep 25, 2011 | Computers & Internet
Registery booster activation code
Registry Booster activation codes can be purchased from Uniblue at the Registry Booster page on their website: http://www.uniblue.com/software/registrybooster/
Mar 20, 2011 | Computers & Internet
What registry cleaner should one buy to keep all programs running effectivly, update all drivers, stop usless programs from running, etc.
The Best Registry Cleaner Is The Uniblue's Product Registry Booster, The Software Will Scan All Your Registry Files And Find The Errors To Eliminate Them From Your Computer And Makes The Computer Fast.
To Download Go To
http://download.uniblue.com/site/prodpage/rb/registrybooster.exe
Sep 19, 2010 | Computers & Internet
I am looking for key for uniblue registry booster?
go to www.filefortune.com sign up and you can download the key.
Jun 25, 2010 | Computers & Internet
Where can I find the Serial Numbers for Uniblue Registry Booster software???I want to Register mine that I downloaded.
you can get a serial from
http://youserials.com/najdem.php?q=Uniblue+Registry+Booster
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 13, 2010 | Computers & Internet
My problem is with Uniblue. I purchased online the package of Registry Booster & System Tweaker. Registry Booster downloaded and works, but I am unable to copy the program to disc as...
Hi Frank - when I click on that link system tweaker downloads for me. Try it again but click on save. Pick a place where you know it is and then run the install from there. If this solves your problem PLEASE rate as fixed. If you need more help just add a comment and I'll be more than happy to assist you further. Thanks.
Jeff
May 01, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
