Question about Philips DVP3960
Philips DVP3960: works, but no 480p, scrambled display
This has been a good DVD player for nearly 3 years now, but, while it still plays, it seems to have defaulted to 480i regardless of whether it's set on 480i or 480p, and the display window often shows constantly scrambling characters, rather than the usual chapter numbers. I tried unplugging it, but that didn't help.
  • John Black Jul 18, 2010
    Thanks for the comments. I've done enough electronic sleuthing that I should have connected the DVP 3960 to our other HD TV before posting the question. I just moved it to the other set and progressive works fine, so the problem must be with the other TV. I'm going to try it there with HDMI to see if that works normally. I've had it connected with component cables.
  • 484 Answers
The problem is from your convergence IC, it need to be replaced. Get a repair guy to replace the convergence IC of your DVD player and the DVD player would be in good condition again.
But before you get the repairman to come fix it, these are simple things you should try out on the DVD player to see if it is just troubleshooting it needs.
Try to disconnect the prong cables from the player and connect it back.
Then you can further try to connect the DVD player to another television to see if it works.
If it works, then the problem is from the connection to the television, but if it does not, then there is a system error that is making the dvd player go back to the 480i.
Also you can get the appropriate software and flash the dvd player, and it will automatically restore the factory settings of the dvd player.
Take care
Posted on Jul 12, 2010
Philips DVP 3982, 4 months old, hdmi connected to vizio tv. Suddenly now it plays sound but not picture. If I hook it up with composite cables it works, but of course the picture isn't very good. I tried a...
I have few options for you to get the video back on HDMI:
1. Try out changing the video resolution on HDMI set up (select 480p..1080p).
2. Play NTSC disc (to get the 60Hz out from Player). If your are in US.
3. Select the TV system as AUTO/NTSC to get the 60Hz out only on HDMI.
4. if the Deep Color option is available in HDMI set up menu..set it to OFF.
Let me know if you tried all these and still no output.
Apr 26, 2010 | Philips DVP3982 DVD Player
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
Player other DVD's films on the this pLAYER
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Setup" button on the remote
9. Press "OK" on the remote
Oct 19, 2008 | Philips DVP3960
Asking For Password Then Won't Finish Load
here is what i did to fix this
1 go to Philips,com
2 find your dvd type / model you have
3 down load the latest sortware / fermware file to a computer "its a .ZIP file"
4 unzip the file to your computer and burn it to a cd-rom disc
5 power up you Philips DVD load the ****
6 this vary importent you well see it it say UPGRADING - NO NOT POWER OFF
wait for it to finish first it took me about 3 minuts
7 after it was done it worked just fine
Sep 06, 2008 | Philips DVP3960
Philips DVD Player DVP3960 1080i HDMI DivX DVP3960/37 trying to find a code to unlock the multi region.
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Done.
Jul 18, 2008 | Televison & Video
I have a Philips DVD Player DVP3960 1080i HDMI DivX DVP3960/37 and I need a code to unlock in my system to play multi region.. Thank you
Press "Setup"
Done.
Convert DVD Player to all regions
I found solution: Go to Google and type - DVD help. There is a site with codes for DVD players. http://www.videohelp.com/dvdhacks/philips-dvp-3260/9309
Just type in the codes by: Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
Press "OK"
Jul 15, 2008 | Philips DVP3960
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
Feb 15, 2008 | Philips DVP3960
Philips DVP3960 Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
