Question about Dell Televison & Video
I have a Dell Demension 4400 and it has a 15 pin video out plug and my monitor has a 9 pin plug. Is there an adapter for this plug? Dan
  • 596 Answers
Hello Dan
You can find this adaptor at any computer repair store, Radio Shack or Best Buys.
Good Luck
C2S
Posted on Jul 12, 2010
I bought a x2gen mg5r4 monitor at the goodwill I've got a power adapter that supplies the proper voltage & amperage to the monitor. It powers up just fine, but when plugged into the computer it (the
If the monitor indicates "No Sync" Make sure your video cable is a high density DB15 end. If it is only 9 pins, you have a DB9 cable or connection. Also make sure the video you have it attached to is enabled and is also a high density DB15. (it will have 3 rows off pins. The DB9 will have 2 rows)
If those are okay it may be broken wire in the cable or on the monitor's DB15 connector/connection.
Dec 18, 2011 | Computers & Internet
Jst a few months back i had bought dell inspiron laptop n it was working on very well but suddely i got to a vertical green line on the right hand side of my laptop screen.... could you please tell me the...
You should have a video plug on the side of your laptop. It might be a 9 pin plug or a 15 pin plug. You can attach an external monitor or LCD monitor to this plug. If the green line displays on the external monitor then your video circuit on your laptop is faulty. If the line is not present on external display then your laptop LCD display panel is defective.
Jan 09, 2011 | Dell Computers & Internet
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Dell monitor doesn't fit my PC.
The cable you're referring to is called a DVI cable and aye, there are adapters. The DVI plug was designed to be universal in that aspect. You should be able to find a DVI-VGA adapter at Radio Shack or an electronics store for a reasonable price.
To clarify, refer to the following: DVI VGA
Dec 03, 2009 | Office Equipment & Supplies
Adaptec fire connect 4300 problems
Hi there i had just seen your problem
try to remove the programm you had installed and then reinstall the windows by the cd that came with your pc/lap but when inserting it make restart and press any key to boot from cd then press R in order to repair
attention : never install a windows different than your pc/lap company ex: dell have dell windowses
Feb 28, 2009 | Adaptec Fire Connect 4300 Retail pack...
My apple mini mac (no intel) hook up mag monitor 780
The Mac Mini has an adapter plug, DVI to VGA.
If you use the adapter and a VGA cable to the monitor there is not a noticeable difference.
Just be sure to know the resolution maximums of the MAG monitor before you think its the Mac.
Feb 15, 2009 | Mag Innovision LT776s 17" LCD Monitor
Monitor comes on but wont show picture
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Jan 03, 2009 | Dell Computers & Internet
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Televison & Video Logo
49 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
