Question about One Step Ahead New Holland Tractor Set
What can cause the transmission low pressure sensor light to remain lit on a 2007 New Holland TN75SA tractor? Transmission fluid level is accurate. No problems steering, hydraulics, and gear shifting. Everything seems to work perfect, but the sensor light remains lit constantly. Tractor has 302 hours and just had the hydraulic filter changed.
Where do one add auto transmision oil to a jeep grand cherokee 3.7l petrol model and what type do one use
The transmission on this truck is sealer, it doesn't have a fill tube or dipstick. To add fluid requires a scanner be hooked up to monitor fluid temperature and a special fill port used under the truck to add fluid.
Sep 13, 2016 | 2002 Jeep Grand Cherokee
Getting trouble code po868
transmission fluid low pressure detected. Root cause is either dirty transmission oil and filter or defective pressure sensor. If you are handy, they can both be changed (filter and sensor) in an afternoon, not expensive. A mechanic could change both in under 2 hours shop time on a sunny day.
Mar 14, 2015 | Jeep Cars & Trucks
Transmission is not shifting right what can i do
what year model type cadillac.could be many things depend on cadillac model, transmission fluid level could be low,check transmission fluid color on dip stick looks dark brown smell burned, replace transmission fluid and filter,transmission fluid could be old dirty, that will cause shift problems, if you have newer type cadillac have vechicle code scan because you have line pressure solenoid, shift solenoids and BAD TPS SENSOR CAUSE SHIFTING PROBLEMS AND FAULTY VSS SENSOR.take vechicle to transmission shop let them use diagnostic euipment see if they come up with a code, they can also check transmission pump oil pump pressure, if pump leak transmission wont shift right or not at all.
Sep 01, 2012 | Cadillac Cars & Trucks
Diagnostic code P1782
P1782 DODGE - 2/4-OD Pressure Switch Circuit Possible causes of this code are: - Low transmission fluid level (check level hot transmission only)
- Dirty transmission fluid (has transmission been serivced at least every 60,000 miles, fluid and new filter?)
- Faulty 2/4-OD Pressure Switch
- 2/4-OD Pressure switch poor electrical connection
- 2/4-OD Pressure switch circuit is open or shorted
P1782 DODGE Description The pressure 2/4-OD Pressure Switch is part of the pressure switch of the transmission. The pressure switch are located in the solenoid assembly. The switch provide input information to the Transmission Control Module (TCM). The switch will inform to the TCM is pressure exist in a specified hydraulic circuit. the TCM uses this information to verified that the solenoids are working or not.
Oct 20, 2011 | 1999 Dodge Caravan
Transmission code p1763 for a 98 Dodge Durango
CODE P1763 - GOVERNOR PRESSURE SENSOR SIGNAL HIGH.POSSIBLE CAUSES SIGNAL WIRE SHORT CIRCUIT TO POSITIVE,VOLTAGE SUPPLY WIREOPEN CIRCUIT,TRANSMISSION FLUID LEVEL LOW,GOVERNOR PRESSURE SENSOR FAILED OR PCM AND TCM HAS FAILED.
Jul 04, 2011 | 1998 Dodge Durango
What does this code mean p0775 and p0735 lincoln v8 2002
P0775 FORD - Automatic Transmission Pressure Control Solenoid B Malfunction Possible causes - Faulty line pressure solenoid B valve
- Line pressure solenoid B valve harness or connectors
- Line pressure solenoid B valve circuit is open or shorted
- Dirty transmission Fluid P0735 FORD - Automatic Transmission Incorrect Fifth Gear Ratio Possible causes - Low transmission fluid level
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
May 27, 2011 | Lincoln LS Cars & Trucks
I have no gears forward or reverse. My Vehicle is a 2003 Dodge Ram 1500 4x4 Hemi with 170,000 on the clock. Fluid is clean and full with no leaks. I have the following trouble codes:...
Your scanner will give you the code but it will not tell you how to fix your vehicle. Scanners basically tell you what systems to check or what systems are failing.
These are what your codes mean:
P0700: Transmission Control Module
- Shorted or open circuit within transmission control module (TCM)
- Failure of transaxle control module. This is just a informative code.
P0734: Gear ratio error in 4th gear
- Shift solenoids
P0732: Gear ratio error in 2nd gear
- Shift solenoids
P0731: Gear ratio error in 1st gear
- Shift solenoids
P0871: Transmission Fluid Pressure Sensor Switch C
P0876: Transmission Fluid Pressure Sensor Switch D
Emissions Codes:
P0400: Exhaust Gas Recirculation Flow Malfunction
- Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR temperature sensor and circuit
- EGR Valve
How to fix :
- Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
P0440: EVAP Emission Control System Malfunction
- Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Incorrect fuel tank vacuum relief valve
How to fix:
- Retight or replaced fuel tank filler cap
- Replaced damage or leaking EVAP canister
P0456: EVAP Control System Leak Detected (Very Small Leak)
- Missing Fuel cap
How to fix:
P0441: EVAP Emission Control System Incorrect Purge
- Missing Fuel cap
How to fix:
Based on the info check your EVAP system. I would check for leaks and maybe replace the EGR and the canister.
For the transmission check the TCM also you may need to take it to a mechanic though.
Hope this helps a little.
- Tech 101 (ASE CERTIFIED MASTER TECHNICIAN)
- Larson's Mobile Auto Repair
- 209-845-7620
- Oakdale, CA
Dec 31, 2010 | Dodge Pickup Cars & Trucks
Od light flashing and stalls when put in drive
HAVE VECHICLE SCANNED SOUND LIKE TORQUE PROBLEMS. OR VECHICLE SPEED SENSOR. CHECK TRANSMISSION FLUID LEVEL.I WOULD DO A TRANSMISSION FLUID AND FILTER CHANGE FIRST IT NOT BEEN CHANGED A LONG LONG TIME. BEFORE GETTING DEEPER INTO MAJOR TRANSMISSION REPAIR.ANOTHER THING MAKE SURE ENGINE WELL FINE TUNED IF NOT IT WILL CAUSE TRANSMISSION SHIFT PROBLEMS. LIKE I WAS SAYING IF TRANSMISSION FILTER STOPPED UP IT CAUSE LOW TRANSMISSION FLUID PRESSURE CAUSING LOTS TRANSMISSION SHIFTING PROBLEMS
Dec 11, 2010 | 2000 Ford Excursion
Where do I check the transmission fluid on a 1997 Hyundai excel
Remove Transmission Fluid Level Check
Locate and remove the transmission fluid level checker, in most cars and trucks this is where the fluid is checked and added.
Insert fluid funnel and add transmission fluid until the proper amount of fluid level is reached. Let engine warm and recheck fluid level, add fluid as needed. Do not over fill the transmission, it could foam the fluid and cause low fluid pressure causing premature transmission failure. recheck transmission for leaks and recheck fluid level in a couple of days.
DIAGNOSIS AND TEST FLUID LEVEL AND CONDITION
1. Park the vehicle on a level surface. 2. Before removing the dipstick, wipe all dirt from the area around the dipstick. 3. With the selector lever in "P" (Park) and the parking brake applied, start the engine. 4. The engine should be running at idle speed and the fluid should be at normal operating temperature [80-90°C (176-194°F)]. 5. Move the selector lever to every position to fill the torque converter and hydraulic circuit with fluid, then place the lever in the "N" (Neutral) position. This operation checks that fluid level check is accurate. 6. Check if the fluid level is in the "HOT" range shown on the dipstick. If the fluid is low, add automatic transaxle fluid until the level reaches the "HOT" range.
Aug 13, 2008 | Hyundai Excel Cars & Trucks
One Step Ahead New Holland Tractor Set Logo
292 people viewed this question
Top One Step Ahead Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you an One Step Ahead Toy Expert? Answer questions, earn points and help others
