Question about GE Refrigerators
Model#LW18JYALW-1 Freezer compartment quit working, just before that, the freezer fan blade was making noise, a ticking sound but it stopped. and then all freezing stopped? please help if you can?
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 262 Answers
SOURCE: GE refer Model #TCS18PADBLBS Bottom freezer
the compressor should reset it self and the fan you just have to dig behind the rear panel for it chances are the blade is rubbing the shroud
Posted on Dec 03, 2007
hotuna
  • 288 Answers
SOURCE: GE GSL25JFR Freezer fan noise.
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Posted on Dec 17, 2007
  • 21 Answers
SOURCE: Freezer quits working
Good Day, I live out in Ca. and have only experience temp's like what you guys endure once in my lifetime. But I grew up, with Bart Starr, he was my guy, leading the Pac. in the Ice Bowl. I'm hoping to get one of the guys to add to my comments I'm going to suggest to you, there are many guys more qualified with more experience than I, that might offer more. Sometimes with Refrigerators and Freezers, is that during periods of long cold spells, the appliances can actually NOT produce enough Run-time to sustain the foods inside. In other words, because its so damn cold it will go off and if the thermostat doesn't sense the temp has risen to the point it needs to come back on, it won't. Ice creams, because of the salt content, bread (it has no density) these will be the first foods to be effected. 20yrs ago I remember we have a strip heater... wr49x211 I think it was, to add heat to get the thermostat to cycle back on.... Check around, ask -Re-post and List it.. I want somebody who knows Refer's, Lives and Works in tough weather... that'll get an answer
Posted on Feb 27, 2008
Freezer is making a loud noise, assume when compressor is on. Pretty much as soon as the door is opened, the noise begins. Things are still frozen inside.
inside the compressor body there are springs which sometimes break and allow the
motor to knock against the outer enclosure. There is no fix for this as the system is
sealed, short of replacing the compressor. Not a problem with operation, but quite
distracting.
On another note, if the freezer compartment is beginning to freeze up or the fan
blade was installed too far back on the shaft, this could also cause noise.
(it will only make the sound in the freezer compartment when the fan is running
if this is the case). Hope this helps.
Apr 28, 2011 | Woods Freezers
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Jan 08, 2008 | Refrigerators
Dec 17, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Jul 27, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
