Question about Gateway FPD1975W 19" LCD Monitor
The LCD keeps turning on and off and it give me an error Theft deferrent mode press menu but when press it turrns off againg
  • 32 Answers
Im going to presume that you are not using the computer that the monitor came with.
You have two options.
1. access the utility and disable the theft deterrent by using the PIN that was entered when it was first accessed.
2. hook it up to the original computer that it was mated to and see if you can disable the "lock", but I believe you will still need the PIN.
you can find more info at the link below
Click Here
Posted on Jul 12, 2010
How i do fix error e161-403e
Try holding the Navigate + Load buttons down while turning it on... keep holding them down, as it could take quite a few seconds before the LCD says Initializing
S should appear at the top right of the display.
Press the < or > keys to choose the Set./Adj. Menu and press the OK key.
SERVICE MODE should appear in the menu list and the MESSAGE LED should flash.
Press the ^ or V key to choose SERVICE MODE and press OK
Apr 29, 2015 | Canon imagePROGRAF IPF710 Printer
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
Mar 13, 2011 | Acer G185HAb 19" LCD Monitor
Will not do a print test. keep giving me an error.
1. Check the ink levels. if they are not low, try to clear NVRAM by pressing the Scan button and the Up button at the same time to enter diagnostic mode.
2. Use the Up button or the Down button to go to the option for Clear NVRAM on the LCD and press Menu to confirm.
3. Press Menu again when asked if you are sure. Press Menu again when asked if you are really sure.
Jul 17, 2010 | Dell S2500 Printer
Refresh rate will not switch to 60 hertz from 59 hertz. Hence my hdmi connection from my desktop to my display keeps showing "out of range" error
turn off the computer restart it and press F8 immediatly before start and keep pressing untill menu appears then highlight on" enable vga mode" and press enter your problem will be solved
Apr 05, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Anti theft mode enabled
you must trub off ur monitor power button on the monitor...
next step is on monitor u can see menu button we must press it and now we should press power button
now ur moniior anti theft mode will be disable
Mar 08, 2010 | Acer AL1916W 19" LCD Monitor
How to solve anti theft mode enable
Anti theft mode enable this message comes in my system pls give me solution it comes after one hour
first power off u r monitor
then press and hold menu button on the monitor then press power button on monitor
Feb 16, 2010 | Acer AL1916W 19" LCD Monitor
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Dec 30, 2008 | Brother MFC-8860DN Printer
Press 99 to exit Maint mode.
Gateway FPD1975W 19" LCD Monitor Logo
214 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
