Question about Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
I have a Kenmore Elite Oasis Electric Dryer, Model No. 110.6703. The cycle signal will not stop beeping and the lights blink between the on off. Any suggestion for what the problem may be?
  • 2 more comments
  • Anonymous Apr 21, 2008
    My Elite dryer is stuck on the jeans mode and will not clear, it keeps flashing and when i turn it on, it continually beeps. help.
  • Anonymous May 08, 2008
    I have a Kenmore Elite Oasis Electric washer Model No. 110.2760. The cycle signal will not stop beeping and the lights blink between the on off. Any suggestion for what the problem may be?
  • Anonymous May 27, 2008
    My cycle signal keeps beeping and the lights keep flashing. There is nothing in the manual about this.
  • Anonymous Nov 16, 2008
    I have the same problem with my Kenmore Elite Oasis 110.67052600 - the cycle signal volume keeps going from low to high, beeping all along. It does this intermittantly, but is very annoying.
    Putting the Dryer into the Diagnostics Mode confirmed a fault code of F2.
  • 413 Answers
The user interface button panel has failed and will need to be replaced.
Posted on May 29, 2008
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Dryer
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Have a Kenmore Elite Oasis Electric Dryer 110.6709...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#@#$
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore oasis dryer cycle signal beeping constantly
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Remember to unplug the unit first.
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Volume beeps from loud to soft
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
Feb 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 110.6703 is BEEPING!!! ARGH!
repl./// user interface board stuck button common problem
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
Cycle signal is going crazy
check vents and venting. sounds like a controller problem and unfortunatly there are no resets for that type of problem
Sep 30, 2007 | Kenmore Elite HE4 Electric Dryer
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Kenmore Elite HE4 Electric Dryer Logo
649 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
