Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
My grundfos MQ 3's motor sounds like it is locked up. When i plug it in everything seems to work except the motor just humms until the alarm shuts it off. There is nothing blocking the impeller. What would cause this?
  • Grundfos Master
  • 43,501 Answers
Either the motor has gone bad and will not start or the capacitor is bad and is not helping the motor to start...an experience repair person can tell tou what is happening...
heatman101
Posted on Jul 12, 2010
No water
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Apr 14, 2014 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Grundfos pump
Louise, since there is several different types and models of Grundfos pumps it would be hard to answer your question. To possible point you in the right direction below are a few links to where you can find some PDF documentation about a popular Grundfos pump the MQ series and direct link to the manufactures "Service Support".
Service support
Grundfos MQ Series Pumps
Feb 07, 2014 | Garden
Grundfos MQ 35 won't run
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Jan 24, 2014 | Plumbing
Grundfos MQ 35
Check the capacitor or the centrifugal switch.
Aug 26, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Triton t200re shower
Paul. Is it only the shower that the pump cuts out? i dont think we have these pumps in AU. Would bet that its a flow issue. Either remove the water saving device in the shower, if there is one. Pr turn another tap on just a dribble when you start the shower?
We have these issues with "smart"? controllers that think there is a leak
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run...
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
May 04, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
1,449 people viewed this question
Top Grundfos Garden Experts
john h
Audrey Messer
Audrey Messer
Jay Finke
Jay Finke
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
