Question about Home
I have bought an arlec MAL800 series flood lights but the back of the light switch shhows 3 terminals A,OUT,N can you tell me which one is which ie live, neutral earth etc. The instuctions only say not to conect the earth. Can you help me please. Thanks Jim.
  • 619 Answers
SOURCE: Terminal Designation
Ok if R is live use tester volt meter 110 volts connect tester from cord terminal one tester connect to R the nmulti tester read 110 volt if ok good .
Posted on Jan 10, 2008
  • 234 Answers
SOURCE: Colour coding
ifu get a bulb on a piece of wire earth 1 end and touch the wires with other when the bulb lights u a live or supply or other ise just get a volt meter hope this helps
Posted on May 03, 2009
  • 41 Answers
SOURCE: Hi, I have just replace the room thermostat on my
Well in your case,if the central heating was working before you change the defective thermoatat.Phaps you have done the wrong connection of the thermostat,if you look well at the connection of the thermostat, how will you recognise the earth borne is that it is fixed to the body of the part,so this means that the thermostat 3 cores are (1) common,(2) normally close,(3) normally open.With a multimeter it be very easy to determine the core that you have to cannect.
Posted on Oct 05, 2009
  • 37 Answers
SOURCE: I have wired a new light fitting into our
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Posted on Nov 13, 2009
barkencoa
  • 3463 Answers
SOURCE: I have just purchased a new electric cooker. The
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Posted on Nov 09, 2010
Install lights on 36volt system
I'm sure the manufacturer of the cart has 36v lights available but an easy way to do it with readily available inexpensive 12v lights would be to simply install 3 wired in series. So positive lead from the light switch to the first lamps + terminal, then the 1st lamps - terminal gets jumpered to the second lamps + terminal, and so on. Then on the last lamp the - terminal gets attached to the cart's chassis or the negative terminal of the battery.
Mar 08, 2015 | Golf
My flood lights have a manual function so that I can wire a light switch to them and use them with switch as well as a motion detector. However the users manual does not provide instructions or diagra
you need to either break the circuit going to the light, so find the wire that powers the light & cut it where you want the switch, then join the black wires together & put the reds in each end of the switch.
or the way you asked about, which will depend on what your light has in the of terminals in the conection box.
ill do you a drawing..........
flood-lights-manual-function-wire-light-kh0zpbanw2f22f2jnqn4pytl-4-0.jpg so take the red out of its terminal in the back of the light, put it in its own conector or a spare one thats already in the light, might be labeled (manual function) then run one 2 core/ twin & earth wire to where you want your switch to be, & then wire it up like the picture, red in com black in either l1 or l2..
go back to the light & take the red of your new wire & put it in the same terminal as the one i just told you to take out, then put the black from your new wire & put it where the red wire was to start with.
your live could be either red or brown depends on the cable used.
check your swith aswell b4 screwing it to the back box, to make sure you put it the right way up,nothing more anoying than an upside down switch.......lol
good luck!
Sep 26, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
I bought a westinghouse 77020 pull chain switch and only two speeds work and fan will not shut off
The BLUE wire is for a light. The red is the "traveler" and the black is power.
Did you use the blue wire without a light? If you did, you wired it hot, full time.
Jan 27, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I have a bad decora switch, how can i tell if it i...
In addition to your answer that was given to you. Look at the amp rating on the switch you just removed. It's probably a 20 amp switch (if you already had 12 guage wire in there, and it worked fine), and you're replacing it with a 15 amp. Happens all the time. As far as the answer given you, its fine. The only time you would use a 4-way switch is when it's being operated by two 3-way switches from opposite ends like the gentleman mentioned. I would suggest getting the correct 3-way switch. It just makes things easier. And again, turn OFF the circuit when working on this switch - or anytime you're working on anything electrical. This is a huge Rule-of-Thumb! I've been doing electrical work for over 27 yrs., and I always turn OFF the electricity.  Best of Luck to you, and I hope this is a little added solution to the one you already have. Take care...Jim
May 19, 2010 | Leviton Decora Light Dimmer Switch
I have to change my light/fan combo wall switch 'cos the fan knob broke. Previous switch was a Martec & the new one is an Arlec. The Martec was wired 2 reds to 'A' and 1 red to 'F' on the fan...
Do not use the capped off black wires. Leave them be. You need the same wires to perform the same functions as before. Of this I am certain. I don't know those particular switches, but here's an educated guess about the rest--- I am assuming that the 3 black wires are connected together with one wire nut. The single red to F is the output to the fan, you have that right. The pair of reds to A are an incoming hot wire, and an outgoing hot wire to another box or outlet that is just passing through. These must remain together. Your old switch had an internal jumper that fed power to both the fan controller and the light switch. Your new light switch is a four-way switch that can be used just fine in your case, but it will require you to add a jumper wire. A 4 way switch can't be used as a 4 way switch if it had an internal jumper from the fan control, so you will have to provide the jumper from that pair of red wires (making them a trio) to one of the 4 terminals on the light switch. Your white wire will be connected to one of the other 4 terminals. Of the four terminals on the switch you should probably use one of the top two and one of the bottom two. If nothing happens (unlikely) then use the top two or the bottom two. If one top and one bottom works but your switch is upside down (the up position is OFF and the down position is ON) then trade one of the wires left and right. If this was helpful, please vote. Thanks, Al K
Mar 09, 2010 | Electrical Supplies
Home Logo
64 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
