Hi i've looked on the side of my pc for every possible code to register my pc because my sound has stopped workin and i've tired everythin and i just want to download a driver or anythin on the packard bell wed site
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 32 Answers
Rather than trying to register your PC, you can download DriverEasy and allow the software to find the best driver for your hardware. If Windows is already registered, you will not need to do this again.
If upgraded the driver does not work, you can use device manager to uninstall the driver and reboot. Your sound should be rediscovered and hopefully start working again.
Posted on Jul 12, 2010
Squealing Tires?
Is it a tire squeal or brake squeal?If it is brake squeal put high temp synthetic brake lube grease behind the brake pads to reduce/remove the brake squeal.This allows the pads to sit on a bed of grease and will not vibrate at the frequency which produces the squeal.
Jun 29, 2017 | 2003 Oldsmobile Alero
2010 Chevrolet Camaro... My TPMS (Tire Pressure Monitoring Sensor) light came on blinking and car is telling me to have it serviced. only 3 of my 4 tires are registering on the system. Is there anyway to...
There is a Technical Service Bulletin (TSB) for your vehicle stating that if the light is blinking and if there are dashes (- -) on only one or two tire pressure readings, then the tire presure monitoring system should be put through a "Relearn" or "matching" process. Then if any of the tire pressure sensors do not respond while relearning, the sensor in that tire should be replaced.
The TPMS matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the engine off.
3. Go to the TPM vehicle information screen on the DIC. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the Driver Information Center screen.
4. Start with the driver side front tire.
5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5.
9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label.
11. Put the valve caps back on the valve stems.
The tires air pressure will not appear on the screen until you start driving the vehicle.
Aug 01, 2011 | 2010 Chevrolet Camaro
On high speeds vehichle shiverring sometimes. and on high speed braking also,and dragging to one side,tyre worning out on the outer side of left tyre.
Sounds like you need a brake job (for shuttering when stopping), new tires because of un-even wear, and possibly an alignment (so the next pair of tires don't wear out. While they are checking, they should check the shock absorbers (struts). This is a fairly old car and will likely need stuts and alignment.
If money is tight, look into some used tires. The brake job is not critical until you hear noise. Keep the speed down if you can't afford the alignment and struts.
-Please rate this answer
Good luck
Nov 20, 2009 | 1994 Hyundai Excel
1995 Astro Custom Van... anti theft will not let me turn the engine... new battery..
u need to unlock the stereo and everythin will start workin or go to a mechanic maybe somethin else is the problem
Sep 07, 2009 | Chevrolet Astro Cars & Trucks
How to reset the tire pressure on a 08' chevy tahoe?
TPMS Sensor Matching Procedure
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. The sensors are matched to the tire/wheel positions in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer/retailer for service.
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire's air pressure. If increasing the tire's air pressure, do not exceed the maximum inflation pressure indicated on the tire's sidewall.
To decrease air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage, or a key.
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
  3. Press the Remote Keyless Entry (RKE) transmitter's LOCK and UNLOCK buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
Jul 28, 2009 | 2008 Chevrolet Tahoe
It keeps adding
sorry it sounds like you're not driving it correctly,
when you total the items up you add each item, then hit sub total, then enter the cash value and hit the CA / AMT TEND payment button, it should then give you the change value
if payment is by cheque or visa you should use the CHK / NS button instead
also please check that the key is turned to the REG position, otherwise it may not operate as you may think.
here is the manual
http://www.casio4business.com/sa/products/downloads/manuals/PCR262_E041206B.pdf
Apr 08, 2009 | Casio Parts Cash Register PC Desktop
No main menu on PS2
Dear Customer,
This might be due to the over usage of the reading lense without cleaning.so i request u to open the console.you would see another cover covering the lense.open tat too.with the help of tissue just try to wipe out the lense n jus turn on the ps2 without closing anythin to jus check whether everythin is workin..if the dvd works,then arrange back or put back everythin back to it's position..hope this would work...else try calling a service engineer.
please rate this solution if it meets ur needs else choose fixya.Thank you...
Dec 16, 2008 | Sony PlayStation 2 (PS2) Console
Sony play station 1
Im guessing your using and antenna plug.
make sure your TV is on channel 3,4 or Video/Game channel.
If that doesn't work, reply.
Feb 26, 2008 | Video Game Consoles & Games
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
