Question about Whirlpool GH7145XF Microwave Oven
Turntable replacement Model gt4175sp Need to replace the turntable. How do you do it?
  • Whirlpool Master
  • 9,086 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you need to replace the turntable motor or coupler, please unplug the unit first. You will need to remove the bottom panel (where the cooktop lights are).
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: turntable replacement
If you also need to replace the turntable motor or coupler, you will need to remove the bottom panel to access the motor.
Be sure to unplug the oven before removing any screws.
I need a glass turntable for my MWM925BSD-B Gourmetwave microwave.
I have a glass turntable if you need one. You can contact me at 306-285-7944
Jun 07, 2012 | Microwave Ovens
MODEL W 201 TURNTABLE DOES NOT ROTATE
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
If the model number is correct, the part number for a replacement motor is 8183954. If the coupler is stripped and needs replaced, the part number is 8206228. The average price for a motor is about $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Whirlpool MH7140XF Microwave Oven
Turntable does not turn, what are possible causes
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10143. The cost is about $30. You may also consider replacing the turntable ring (part number WB06X10545) if it shows signs of wear.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 09, 2010 | GE JES1656SJ Stainless-Steel 1150 Watts...
I have a Sharp 930 Convection Microwave that is no longer rotating. Any help?
This problerm is commonly attributed to a turntable motor that is no longer working. If the model number you posted this question under is correct, the part number for a replacement turntable motor is 46-841666-3. You may also consider replacing the turntable coupler (also called the turntable shaft). The part number is NCPL-A021WRFO. If your existing coupler is still in good shape, there is no need to replace it.
Replacement parts can be purchased on line at searspartsdirect.com. There is a complete list of helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
Jan 29, 2010 | Sharp R-930AK Convection/Microwave Oven
Estimate of 21v AC turntable motor, also the plastic spindle?
If the model number you posted this question under is correct, a replacement turntable motor costs anywhere from $25 to $35 on average. The turntable coupler (also called the turntable shaft) can cost anywhere from $5 to $15. This all depends on the exact model number.
Replacement parts can be purchased on line at any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites on the list also have helpful exploded view parts illustrations to assist you with parts identification/location.
Jan 28, 2010 | GE JVM1630 Microwave Oven
I have a Hotpoint Counter Saver Plus Microwave model RVM1435wd. The turntable does not rotate. How can I fix it?
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
Jan 24, 2010 | Hotpoint RVM1435 Microwave Oven
Apr 19, 2008 | Microwave Ovens
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
I need to purchase a replacement turntable support
The turntable support ("roller guide asm") is actually ref # 28 and runs only $22.11. See http://tinyurl.com/gv383
Oct 16, 2007 | Microwave Ovens
Whirlpool GH7145XF Microwave Oven Logo
49 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
