Question about Nokia 6300 Cellular Phone
There is a network problem in 6300 chinese mobile how to solve it
How can I unlock Nokia 6300 mobile phone?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 28, 2012 | Nokia 6300 Cell Phone
Unlock code for nokia 6300
hi whether your want code to unlock your nokia 6300 mobile from network lock then visit wickedunlock.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you code to unlock your mobile.
Aug 22, 2012 | Nokia 6300 Cell Phone
Gmn cara buka restriction code nokia 6300, ime saya 12345610654321
somebody can help me...need to unlock my nokia 6300 , IME 359812014464791 .
Jun 05, 2012 | Nokia 6300 Cellular Phone
I need restriction cod for nokia 6300
If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6300 model mobile can be got at Superunlockcodes.com which gives easy instructions to unlock your mobile.
May 14, 2012 | Nokia 6300 Cellular Phone
Dear sir, i needs a solution for chinese nokia 6300 mobile's white screen problems so help me how i can solve this problems please.......... fast help me sir. thank you
Remove the memory card and battery replace batterry after 30 minutes to hard reset. If the phone boots up then check card for errors, virus, delete, format as required and reset.
If this wont solve , you will need help fromNokia care to reinstall the software.
Sep 30, 2010 | Vacuums
Signal problem
Dear customer
I will get vary happy to help u. If u are a Technician then open ur mobile handset by T-6 screw driver and firstly wash ur network antina and IC areas by a toothbrash with PCB cleaner.Check the network connecter make a jumper from network connecter to connecter pins by micro soldering IRON and give some hot air to network IC with pest.If u are not a technician then its better to go ur nearest NOKIA care center.If u are saticfied withmy information then please vote me. Thank you for your visit.
May 24, 2010 | Nokia 6300 Cellular Phone
My chinese mobile zeorgia z1 is having GPRS but not working
you must get the details from yor service provider and key it into ur phone manually in "connectivity settings"..
i cant direct you step by step cos koream phones have different softwares on different phones
Aug 05, 2009 | Nokia 6300 Cellular Phone
I was programming it and hit a wrong key in the language section of the phone. It's now on Chinese and as I can't read Chinese I can't get it back to English. Can you help me please?
enter code *#7880# it reset your setting.when you enter your mobile ask security code enter security code then your mobile restart come back on default settings
Jul 30, 2009 | Nokia 6300 Cell Phone
I have a new Nokia 6300. I hit the wrong key and now everything's in Chinese. I know which icons needed to change language but as I can't read Chinese, it's impossible. Any help please?
Just take any close model or exact of nokia handset from your friend. Settings in all the nokia models above 3500 is same just read in english at your friends mobile and click the icons on your mobile till you reach language selection option and on your mobile select english.
GPRS setting for A968 china mobile
I m using sigmatel s90 the chinese phone. but airtel service does not have the Settings for GPRS or NOP. Can someone send me the manual setting for Chinese sigmatel s90 phone.
Plz help me out
Nov 10, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
112 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
