Question about Fisher and Paykel GWL11 Top Load Washer
My GWL 11 is stuck right before the rinse cycle. It will not drain. The two orange rinse lights and the red spin light is on, and there is a quiet electrical humming sound.No error beeps. I've already unplugged it, waited, and tried again. No luck. It will agitate, but won't drain or spin.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now bail some of the water out by hand with a pot or small bucket so you can lean the machine back far enough to look underneath the machine without it leaking everywhere.Now when are looking underneath the machine look to the front right and you should see a red or black fan,This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen the pump if any thing is jammed.The fan should spin freely.Now put the machine back on its feet and select a spin cycle and hopefully the machine starts to drain.Please reply to tell me how you got on or if the machine is still not draining or you have the other type of pump.Good luck.
Posted on Jul 12, 2010
  • 1 more comment
  • KangarooTott Jul 18, 2010
    We had a similar issue: macvhine washed, but would not spin or drain. Machine cycled water in, as if it were about to spin, but lid never locked and spin cycle never kicked in. Diagnostic test indicated drain pump is blocked. We tried this solution, and it worked - while the machine was empty. As soon as we put clothes in it, the problem recurred. We have now bailed the machine out 4 times and are at our wits end. Any other suggestions?
  • luisa_sgro Aug 08, 2010
    Peter just read your posting.Please don't drill any more holes in the machine.The fault on your machine is BOWL CHECK FAULT.Please reply to this posting so I know that you are receiving this message because you have put your posting on another persons section.Please reply as you have done and I will check this spot until I see your next posting.
  • gingerzeb Aug 22, 2010
    Same exact issue. Tried solution. Machine works perfectly. Looked like typical dust accumulation around black fan. I guess my Spring cleaning will include dusting under the washer.
  • 3 Answers
I had a similar problem, however, it did beep when it stuck on the wash cycle and would not agitate. I tried to get a diagnostic code, but it would not display any. I than decided to disassemble it. When I removed the basket, I heard and felt water sloshing in the bottom cavity. If I understand the design correctly, this plastic cavity on the bottom should be hollow and empty to allow the basket to float upward as the water level rises which allows the machine to agitate. I drilled two holes in the bottom and drained out most of the water. I than sealed them with epoxy. The machine worked fine afterwards. However, I can't tell just where the water entered, so I called Fisher and Paykel for a price on a new basket or bowl liner assembly as it's called in the parts breakdown. Their price was $160 plus $50 shipping. Rather than buy it, I purchased a new front load washing machine.
Posted on Jul 14, 2010
  • peter970 Aug 08, 2010
    I have a similar problem. My GW611 fills and drains but will not agitate or spin. I can hear water sloshing somewhere inside but cannot see where. Sounds like quite a bit of water behind the drum wall. I tipped it over and drilled a hole in top rim, some water drained and machine worked fine for a week. Now problem is back. Does not progress through cycles, but will progress manually. Fills and drains, does not spin or agitate. Beeps and ends with green lights 3,4,5 showing. Where should I drill next?
When I try to drain rinse and spin the machine goes from orange light to red light...then back to orange light again Please help
I am assuming that this is a front loading machine. Does water drain from the machine? It is possible that the input to the drain pump is clogged or the drain pump may be bad.
Oct 29, 2016 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
I have a fischer and paykel top loading washing machine for the last few years that that given use excellent service. In the last month when a programme is run the machince gets stuck at the rinse cycle...
Hi dude - is this a replica of the lights - where I put 0 theres no light, 1 is a light ok you follow? on the top is 8 lights from left - right the first 5 is always green, next 2 is orange & last is red! so I will try and see if we are on the same track...
Here goes - 0010 0101 is this what you have? - if yes then the pump is either overheating of severely blocked - more likely to be overheated.
This is how the washer works. it fills, washes then rinses - now pump starts up as machne joggles and agitates to set up for a spin, then final rinse - as it goes to end it does the same as in rinse.
Therefore I tend to think we would be looking at the same lights on your machine - to my illustration -
Keep the chin up - if you need to replace the pump then look up other F&P request or look up my solutions to help you.
KK
Jun 24, 2011 | Fisher and Paykel Washing Machines
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
678 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
