Question about Friedrich QStar SQ05J10B Air Conditioner
Air conditioner goes like on and off when theramastat kicks on
  • 6,927 Answers
Find the probe from the thermostat,and move it away from the evaporator coils,it is in the front of the coils,behind the filter.If this was at all helpful,please rate,thank you.
Posted on Jul 12, 2010
Furnace will not kick on
going out on high limit which requires manual reset
Dec 15, 2013 | Intertherm P3RA-048K Air Conditioner
Turned unit on for first time, it will not kick on
does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
Jun 04, 2010 | Carrier 38CKC030 Air Conditioner
My Air Conditioner is Not kicking in only for 2
Can either be low on refrigerant or the compressor could be binding on start-up. You may well need a technician to help you fix this.
May 26, 2010 | Intertherm P3RA-048K Air Conditioner
No forced air.... compressor unit and furnace do kick on
Bad blower motor/capicitor or relay. Check the fuse if it has one.
Aug 11, 2009 | Heating & Cooling
My roof dometic roof top air conditioner runs but will not cool when the motor kicks on it goes right back off and will not cool
Check run capacitor, or in the compressor wire box, there should be a little black overload that might be weak or loose connection.
Aug 02, 2009 | Heating & Cooling
Ac window unit comporesser doesn't kick on consistantly
try switching off and on power from the plug it might reset itself
Jun 22, 2009 | LG Heat cool Window Air Conditioner
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Friedrich QStar SQ05J10B Air Conditioner Logo
66 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
