Question about Amana AP095R Portable Air Conditioner
My Amana portable A/C was working fine till I decided to move it 2 flights up for the kids to use in their bedroom.When I first tilted it to lift up the stairs it leaked some fluid after that, when I brought it upstairs it would not start or anything. I don't have a manual so I don't know what to do to make it start again . Can you help me. The Amana portable A/C is the AP095R model 9000 BTU.
  • johnmassas Jul 13, 2010
    The solution sounds great and simple .Later in the evening i"ll try it and take it from there.Thank you very much for your time and suggestions.
  • 6,826 Answers
First, the box says that such air conditioners should not be transported on their side. This messes up the refrigerant in the unit.
Second, the fluid that came out was water, and could have gotten into the electronics.
Remove the water from the unit's reservoir, and let it dry out, and try to start it another day upright.
Otherwise, the 9000 BTU unit, may need service from the manufacturer.
Good luck on this.
Posted on Jul 12, 2010
Trouble with hydralics
It MIGHT be low on fluid - that might explain its inability to lift fully. As to the tilt, if it moves slowly at first, then speeds up, that sounds like it has an air pocket that needs to be bled from the tilt hydraulic cylinder(s).
Aug 04, 2014 | John Deere Garden
90XL case
It sounds to me like your hydraulic pump has failed! The hydraulic pump is the semi squared component with two larger hoses and several smaller hoses connected to it! Unless the coupler drive has failed could be the only other possibility!
Jul 13, 2014 | Vehicle Parts & Accessories
I have the Amana portable 3 in 1 air conditioner model #ap077r. It works fine but air only comes out of the right half of the fan vent. Is this how it is supposed to be and if not, how can I fix it?
It probably has 2 evaporator fans and one has failed. (I couldn't find your model on the Amana site, so I don't have any additional information.)
Jun 20, 2014 | Heating & Cooling
What are the ailerons parts of the airplane?
Ailerons tilt the wings of the planes by pushing down the air. Ailerons on both sides work in opposite directions. As one aileron moves up, the other aileron moves down. This helps the airplane to turn during flight.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Midea portable air conditioner leaking water from bottom
Do you have it tilted back slightly towards the outside? It will drain on the inside if not tilted properly.
May 05, 2012 | Amana Heating & Cooling
Moved from one location to another and it will not cool. It was working fine at first location
If you tilted the fridge during the move and then switched it on as soon as you installed it in the new position, you have damaged the compressor and will need to replace it. A fridge should stand at least three hours after being moved before switching it on again so that the fluid in the system can settle into the compressor so that it does not start 'dry' and burn out.
Jul 11, 2011 | Amana Refrigerators
Yale diesel fork lift forward tilt not working back tilt fine
Other hydraulic functions work so it won't be a lack of pressure - likely to be a control issue though not necessarily a lack of supply through the valve.
If the tilt ram is a single double-action type of ram one side must be exhausted in order to move when pressure is applied to the other end.
If the oil can't be exhausted from the lazy end it won't matter how much pressure is applied to the other end.
Feb 11, 2018 | RC Toys
Craig portable dvd player CTFT701
My screen would flicker when you tilted it back and forth. Sometimes it would cut out and moving it would make it come back on. I took the battery off and opened the screen from the front(2 screws in hinge & 2 screws under rubber plugs). There is a ribbon plug inside. Mine looked kinked in one spot so I just repositioned it so the kink was in another spot. Everything worked fine after that. Hope this helps.
Aug 03, 2007 | Craig 731398407019 Portable DVD Player
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Amana AP095R Portable Air Conditioner Logo
90 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
