Question about HP Deskjet F4180 All-in-One InkJet Printer
Paper jam cleared a paper jam and now the printer will not turn back on.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
Ensure all paper pieces have been removed, you might have damaged some circuits or wiring. If still do not want to power-on take to vendor.
Posted on Apr 19, 2008
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
False paper jam on hp laserjet 4345
Feb 06, 2013 | Office Equipment & Supplies
Says paper jam, but there is no paper jam
Nov 20, 2012 | Kodak ESP 5 Printer
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
    As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
    Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    Paper jam
    You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
    Also see this:
    Issue: Paper is jammed inside the printer
      Note:
    7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
    Top
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Clear paper jam
    does the printer have a cancel botton if it does push it
    Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
    HP Deskjet F4180 All-in-One InkJet Printer Logo
    78 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
