Question about HP Compaq nc6000 Notebook
I think my compaq mini was dropped now my screen is red and flick
I think my compaq mini was dropped but im not sure. my desktop is red with a big black spot in the middle and when i pull up internet explorer everything looks like xray........very annoyed!! please help. is this any easy, cheap fix??
    Guru:
  • 551 Answers
I really don't know if was dropped or it was been press hard. But the problem is the LCD of your laptop. I don't know also how much it would cost you to replace the LCD. Because here in my country LCD is expensive its like you bought another mini.
But like I've said, the problem is the LCD. Now if in case it was dropped, check if the hard disk is still good. If not you need also to replace that. Of course replacing hard drive means new installation of all your softwares.
Posted on Jul 12, 2010
I want to factory reset a mini 10 but screen is broke(i am using t.v) im afraid to start the process and then not be able to see anything after
Yes that could be horrid. Try setting the tv as your only screen. If you go to l settings Navigate to the "Start" menu, and click it once to open it. Select "Control Panel." Click "Adjust Screen Resolution" under "Appearance and Personalization." Click the drop-down arrow next to "Multiple Displays" in the window that opens. Select "Show Desktop Only On 2." Windows will disable the Mini 10 display and use the external monitor as the primary screen Read more: How to Run an External Monitor on a Dell Inspiron Mini 9 ' eHow.com http://www.ehow.com/how_6821296_run-dell-inspiron-mini-9.html#ixzz1hFvetaud
Nov 25, 2011 | Dell Inspiron Mini 10 Notebook
I have a Compaq Presario PC, SR5210NX Processor with Intel Celeron Processor 420. I got a message that windows did not start correctly and it said to run the diagnostic, which I did. After that was done,...
Unplug power and Open the computer case. Vacuum all the dust
inside it. Visually inspect all the fans: Power Supply, CPU, Chipset
and Case...Make sure they are spinning easily and freely.
Plug the power in, and turn on your system. Watch the fans, especially
the CPU Fan and the Main Board Fan (System Fan). Oil and dust over
times may accumulate and prevent the fans from spinning properly.
If you are handy, you can remove them, give them a good wash and lubricate
the shafts with a few drops of WD-40, they will be as good as new again.
Fans don't go bad that easily.
Jul 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
I bought a brand new compaq mini 102 with windows xp installed in it. Once i turned the unit on, it takes long time to boot and if i open a folder or a file, it took minutes to respond. How can this be...
hello,
I think you have a virus threat in your laptop.
if you are using internet than you must use a good antivirus programme & First you install a good antivirus & scan your laptop it will surely fix your problem.
if above doesnt work than u can do defragmentation of your harddrive it will surely help you.
Thanks
Dec 30, 2010 | Compaq Mini 102 NetBook
Internet would not work and then whole system froze. Powered off my holding start up button. Now everytime I try to cut it on it is stuck on black compaq screen. Have tried pressing esc, f1 and f8,...
Not too much.It seems you had a corrupt HD do to a virus or other issues.depends on your OS you can try to get some "boot files" in order to try to boot back your PC. After that if you cant do it you will need to re-install your OS.
Oct 12, 2010 | HP Compaq Presario SR1215CL (82916052980)...
Dropped olympia video camera.screen has went completely blank in camera/record mode.help
The same thing happend to my computer when I dropped it. A friend fixed it, but I'm not sure of what he did. I think it is a cable sending information to the screen to tell it what to show that is broken.
If i'm right, the problem isn't so big, but unless you know something about videocameras, don't try it yourself!
Dec 28, 2009 | Panasonic NV-GS15 Mini DV Digital...
It will not come on. It shows in the mini screen
sir i want to download free soun driver for compaq c500 lapop
Apr 11, 2009 | Compaq Presario PCCOM2232US Notebook
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Not Loading
i m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
regards..
for any quarry u can mail me at-sigma_shiva1@yahoo.co.in
May 18, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
HP Compaq nc6000 Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
