Question about Danby DPAC8020 Air Conditioner
Model No.MPK 10CR The red light says full. /and it says P1 on the screen. No cold air.
  • 37 Answers
Water bucket is full. Empty the bucket. If that doesn't work...then pull the little metal adjustment arm down so that the water bucket can make better contact with the water bucket. The level arm is inside the opening where the bucket arm goes in
Posted on Aug 21, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Everstar MPK-10cr blowing hot air
Sound like the back lower motor that turns the fan wheel in the back has failed or needs to be lubricated. I used a little bit of silicon spray since it resists moisture. You can try taking the back off...then the front...then take loosen the front motor fan wheel housing and lift up enough to access the lower back fan motor. I then sprayed the motor housing openings as close to the inner part as possible. That also stops the common noisey fan issue.
Jul 20, 2009 | Heating & Cooling
Midea MPK-10CR air conditioner "P2"
If the drip line is raised too high, sometimes the level inside will exceed the trip-point for the pan-level.
Try lowering the drip line so the water runs 'downhill' the whole way. If it still occurs, the sensor in the pan may be stuck.
May 03, 2009 | Midea MPM-08CR-BB4 Portable Air...
Danby DPAC8020 Air Conditioner Logo
351 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
