Question about Coleman Cable Weekender Portable Hammock by Coleman - Willow Stripe
Impossible to set up. The chain seems to short to attach. It just won't stretch enough.
You can buy longer chain or replace it with a rope, here is the website where you can find some parts for your hammock http://www.hammock-company.com/
good luck
Posted on Jul 14, 2010
How to set timing
your car has a timing chain, if it stretches out far enough it needs to be replaced. It has an automatic adjuster on it to keep the timing correct as it stretches, when the chain stretches beyond any more adjustment you need to change it before it breaks.
Apr 02, 2014 | 1998 Chevrolet Cavalier
Tensioning dial wont tension enough
maybe the chain is stretched to its limit and cannot be adjusted any more?
Sep 10, 2017 | Homelite Ut43103
12v battery attached to on off switch attached to small set of neon flexy lights 2 pin fuse attached to positive line and i have used a 15,20,25 and 30amp fuse and all have blown. strangely enough its only...
All have blown strangely enough?? You have a short circuit, quit installing higher rated fuses find the shorted wire. You are going to start an electrical fire if you keep this up.
May 18, 2012 | kawasaki ZX-12R Motorcycles
Chain will not stay tight
If the chain has come lose due to stretching, then it is not getting enough oil to the bar for the timber you are cutting.
Apr 19, 2011 | Poulan Genuine Chain Saw Complete Gasket...
When should the timing chain be changed on a 1998 2.5 td Limited?
The 2.5 engine has a relatively short chain when compared with many other engines.
In 99.9% of chain failures, the chain does not actually snap but stretches and wears, allowing it to ride up on the cam gear as it turns. That excessive slack allows the cam timing to run slightly behind the crank position and ignition timing to be similarly altered. On engines using a nylon toothed cam gear, the chain running up on the teeth puts stress above the aluminum support inside the gear teeth, allowing the nylon teeth to shear off (Jeep gears are steel and do not share that problem)
Chain wear and stretch is a multiple of the number of links in the chain. A long chain with equal wear on all links will have more slack than a short one as the wear is added together as a total.
The only two items that will cause a chain to wear faster than normal are lack of oil and severe overheating. (assuming the use of a good quality oil).
So, all that said, I'd expect a short chain to last at least 200K miles before becoming worn enough to need replacement. If the engine was not well maintained and has gunk buildup or was severely overheated at any point, I'd shorten that up to perhaps 175K. If you remove the cover to inspect it, then I'd replace it regardless of it's condition as the amount of labor involved is pretty much the same and the chain and gears are not very expensive. If replaced anywhere after 150K it's likely the new chain will outlast the remainder of the vehicle!!!
Jan 10, 2011 | 1999 Jeep Cherokee
The brand new blade rolls off the pulleys, thus not cutting. help!
You need to pull the bar out to tighten up the chain. The chain will stretch a lot the first day, And it will come right off. Check out the adj screw on there and loosen up the lock bolt/s, tighten up the bar, tighten up the lock bolts, Make sure the chain moves, not so tight it gets hot and freezes up. You should be all set. If the chain is stretched beyond the adj, you will need a new chain or get a link taken out of the old one, the hardware store, saw shop can do this for you.
Nov 28, 2010 | Garden
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Do timimg chains need to be replaced (not a belt)?
Timing chains do need to be replaced but they can typically go much longer between being serviced than can timing belts. The chain will stretch out over time and can 'jump' timing. If you have an interference engine then that can prove disastrous as the piston can crash into the valves.
Its not terribly common for a timing chain to jump timing but not impossible. I have a vehicle with nearly 120k with a timing chain and its never been replaced and is still in good shape, I have another vehicle with 170k also with a timing chain that has never been replaced.
If it were me and I was going to be doing some work in that area and had easy enough access to the timing chain, and the mileage was getting up there, I would replace it. Timing chains typically also have a tensioner, so if you replace it, dont forget this item.
Dec 31, 2008 | 2006 Toyota Corolla
Flat belt to hard to stretch
The belt number is 38528035 and it will stretch far enough to go over the bigger pulley.
May 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Coleman Cable Weekender Portable Hammock by Coleman - Willow Stripe Logo
166 people viewed this question
Top Coleman Cable Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Coleman Cable Garden Expert? Answer questions, earn points and help others
