Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Takes about 15-20 minutes to warm up. Has lines on left and right of TV after it warms up. Colors look good. Only problems seem to be lines on left and right sides of TV.
  • 4,889 Answers
Does this happen when using all input sources? Did you try DVD or something to see if problem persists? Do you notice any buzzing sound when this problem occurs? Please provide this info so that i can help you with your problem.
Posted on Jul 12, 2010
  • 2 more comments
  • jgkujath Jul 12, 2010
    All inputs do the same thing. There is no noise
  • eagle338
    eagle338 Jul 12, 2010
    Ok. The there is no problem with the deflection ICs. In such a case I would check the caps around HOT(horizontal output transistor). Do you see any that have swollen tops or cracks(or tiny holes) at the top. you do then you are gonna have to replace them with those of same specs. Not recommended that you do it yourself if you do not have prior experience in handling electronics. The caps hold dangerous voltages for several days after being turned off. They have to be safely discharged before you start working on the board.
    Can you help me find the HOT? I'm an electrician and I do have a general knowledge about circuit boards but I have not openned the back of the TV yet. I will be doing that tomorrow and hopefully any bad caps will be easiby seen.
    Jul 12, 2010 - Ok. The there is no problem with the deflection ICs. In such a case I would check the caps around HOT(horizontal output transistor). Do you see any that have swollen tops or cracks(or tiny holes) at the top. you do then you are gonna have to replace them with those of same specs. Not recommended that you do it yourself if you do not have prior experience in handling electronics. The caps hold dangerous voltages for several days after being turned off. They have to be safely discharged before you start working on the board.
  • eagle338
    Sure I can. Just send me a high res pic(upload it on imageshack.us and get me the link to the image) and I will mark the hot for you. Even better if you can get me the images of the caps so that I can mark the ones that I think are faulty.
Sharp LCD TV Takes 20 minutes to warm up
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 12, 2016 | Sharp Televison & Video
Sharp LCD TV Takes Too Long to Turn On
Your TV main board is failing, soon it will not turn on at all, plan on buying a new one soon.
When tv is turned on, only half of pic is there (left side)..The right side looks like a bar code, with horz. and vertical lines..There is color behind these lines....After it warms up or a couple hours...
This tv is a standard CRT(tube tv) wright?Yes,than the tv video board have problem with dying capacitors or the main colors decoders IC require resoldering.U have a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders and also understanding basic electronic wright?Take the tv aparts check all those capactors all around the main colors decoders IC for capacitors leakages,replaced all these dying leakages capacitors,will solved this problems.These capacitors alway bulges up or puffing up on it top.That the indication those capacitors are dying and not working to it full capacity.Also resolders the colors decoders IC too.Ur tv problems,will be solved.
Nov 15, 2010 | Sylvania Televison & Video
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
After tv warms up, red colors/tones disappear
i have the same set. try bringing down the color temp, for that matter maybe even lower the rest of the settings too. sounds like a lamp replacement?
Apr 22, 2009 | Televison & Video
1993 Buick LesabreTransmission takes 20-30 minutes to warm up
I think you need to have the transmission filter changed, and right away. If that doesn't solve the problem, then have it tested at the transmission shop. Rick
Apr 15, 2009 | 1993 Buick LeSabre
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
Tv go thru different functions on its own after being on for a few minutes.
after it warms up, and starts your problem. turn tv off. unplugg it. then feel the tops off all the caps for heat. also check the hv wires for leak and fluid leakage on boards. could be a possible broken trace or cracks in solder. possible in signal board.
Apr 09, 2008 | Hitachi 51G500 51" Rear Projection...
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
