Question about Air Tools & Compressors
I have a 98 smith 100cfm pull behind compressor .it runs good just used it. Yesterday started it up oil presurevolts good it shows 120psi on air gauge but when i open ballvalve forair nothing comes out switch is in run position seems like it does not rev up. When i pull pressure relief valve open compressor does rev up i am not getting any air
    Master:
  • 381 Answers
Sounds like something is stuck or clogged.
Be careful because you are working with pressure.
Posted on Oct 24, 2017
SOURCE: air compressor 3 gallon
I had mine do the same thing... The head gasket blew out between the intake & discharge side.
I went to O'rileys and bought the blue gasket paper and cut out a new one ($3.00) works fine now.
Just take off the plastic cover, undo the discharge line at the compressor head, remove 4 allen
head bolts, lift off cylinder head and you'll see the gasket gone at the center bridge.
Draw a picture of the way the valve plate under the head is assembled so it goes back together right.
Use care cleaning the old gasket off, NO power tools....Hand wire brush to preserve the little ridges
that bite into the gasket, Soak with solvent helps..You can also order the gasket kit from Sears
about $12.00...Hope this helps ya......John
Posted on Oct 31, 2008
  • 1400 Answers
SOURCE: Craftsman 25 gallon compressor wont cut off
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Posted on Dec 12, 2008
  • 140 Answers
SOURCE: Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
Posted on Jan 22, 2009
mrhappyface
  • 205 Answers
SOURCE: air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Posted on Mar 23, 2009
SOURCE: The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Posted on Apr 01, 2009
The air condition wont turn on. The windows dont work, and the spedometer doesnt work
This just happened to me yesterday. First, push the AC button to turn the AC off. Then, find the fuse pannel on the driver's side under the dash. Mine is behind the ash tray. Replace the 10 amp fuse (marked fuse #18 on my 1995 Camry manual) and the windows, spedo, tach, etc will come back on. My problem is the bearings on my AC clutch heated up a plastic piece between the AC clutch and AC compressor and the plastic piece blew up and sprayed hot plastic all around the AC compressor. The car runs, but no AC and if I push the AC button, the fuse blows again. I am planning to unbolt the compressor from the engine block, and replace the clutch assembly and pully without disconnecting the hoses. Disconnecting the hoses will vent coolant to the atmosphere and require professional equipment to clean the oil from the system, pull a vaccuum and recharge the system. The AC compressor clutch assembly is available at Advanced Auto for $98. The whole compressor is $247 but requires a lot of work to recharge. You could also take the clutch assembly or whole compressor off and just leave it off and get a shorter (40" in my case) belt to go just to the alternator.
Good Luck.
Jun 25, 2011 | 1995 Toyota Camry
Will turn over with plug outbut is very tough to tturn over with plug in.no excess oil or gas in head ,new plug ,lots of oil.float in carb is free .seems not to be hydro locking.is it shot?very few hours...
running out of fuel is a bad thing but will not cause damage. take off the ohv cover. you might have to loosen and prop the petrol tank up to aid in removal. when you have the cover off check the valve assembly and look for cracking on the arms or broken pushrod.
Jan 07, 2011 | Honda Quincy 17 - Gallon Air Compressor...
Ingersoll-Rand Air Compressor P185WJD why would the pop off valve on the air separator keep popping off
its because the compressor is not unloading { going above 120psi} you need to check the air signal going to the unloader valve located on top of the screw, it should start putting out air at about 90psi to close the unloader. another thing is if you are getting oil in the air coming out of the front ball valve the seperator element is bad thats the filter inside the tank the pop off valave is mounted. you can check the air signal by fethering ball valve to run the machine at 90 psi the diconnect small air line on unloade to check for air signal coming from regulater
Jan 06, 2011 | Ingersoll Air Tools & Compressors
Dewalt air compressor keeps running until pressure output is 200 PSI, the same pressure in the tank. Why doesn't it quit running at 120 PSI the designated pressure on the compressor?
The regulator switch/unloader is bad or out of adjustment. Perhaps though the gauge is faulty. 200 psi in a 120psi compressor is dangerous, don't run it until it is fixed!
Dec 15, 2010 | Dewalt Air Tools & Compressors
I started my air compressor for the first time without any oil. Now it makes a buzzing noise. Is there a "simple" solution other than replacing the motor?
Running compressor without out oil generally will damage rod and deposit metal on crank lobe. Metal can be removed using 400 grit sandpaper cut into one inch strips pulling back and fourth untill lobe is clean as new. You will only need to buy the rod(about $20) and one sheet paper. Remove pump/motor from frame, remove two bolts holding cylinder to body and airline and pull up on cylinder to expose piston/rod. Usually the rod will slightly coat the crank with metal and seize. Remove or work rod off lobe. Clean crank area and add fresh oil. Parts available at www.toolpartsdirect.com Good luck
Sep 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
The air tanks fill with air, but the pressure
The regulator sounds like it is cranked closed. Try slowly operating the adjusting knob in the opposite direction. As the valve moves, you should see the pressure rise on your gauge (it probably does work).
Hope this helps....now go make something!
Best regards, --W/D--
Jul 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Air Tools & Compressors Logo
494 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
