Question about Maytag Neptune MAH5500B Front Load Washer
Nd on washer
My machine starts washing and half way through it flashes ND and the water is still in washer...Help can't find my manual.. Thanks Zandra
    Brigadier General:
  • 8,619 Answers
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Will not rinse flashes nd on the screen
The ND means no drain. My Samsung front loader allows coins and other pocket debris to get through to the pump jamming the impeller. ND or SUDS is the error message. I have to use a shopvac to suck the water out through the drain hose and open the back to get to and free up the pump, The pump is easy to get to and easy to remove. Be sure to unplug the machine first.
Apr 17, 2014 | Samsung WF410ANR Washer
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not drain, comes up with code nd. drain hose is not kinked and pipe is not plugged
How much water is left in the Wash Basket when you fail with the ND error code?
The reason I ask is you could have a bad pressure switch false signaling the Control Board.
You will need the Service Manual to start troubleshooting;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does nd mean?
The nd refers to NOT DRAINING and the next step may be "he" error which means that no heat will be forthcoming to dry.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung WF203ANW Front Load Washer
I am getting a nd flashing on my washer
ND means no drain. You can remove the back panel to access the drain pump. Remove the hoses fron the drain pump and remove the clog. Watch out water will drain out when removing the hoses. hope this helps....
Oct 27, 2009 | Maytag MAH8700A Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Maytag Neptune MAH5500B Front Load Washer Logo
272 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
