Question about Haier Heating & Cooling
Have haier outdoor air conditioner compresser comes on but fan does not unless you spin it
    Scholar:
  • 66 Answers
It probably needs a capacitor. If you have a voltmeter that will check microfarad, you can check it. You did not say what size unit you have. But the fan is likely a 5 MFD It will say on the old one. The old one probably has 3 terminals on the top and is a cylinder. The top will be marked C, Herm and fan. You can buy a 5 mfd capacitor for about 10 bucks. Run a wire from the C side of the old capacitor to one side of the new one. Remove wires from the fan side of the old one and put on the other side of the new one. Be sure you secure the new one in a place where it cannot short out. Most of the time this can be accomplished with a wire strap.
As always be sure to disconnect the power before servicing. Also disconnect the power on the furnace. This will prevent any damage from occurring to the inside unit.
Posted on Jul 12, 2010
Coolant fan doesn't come on unless I run air conditioner.
"Coolant Fan" is not necessarily a common term used to refer to any particular fan in a standard HVAC system. Are you referring to the "Indoor Fan" that circulates the air within the living space???? OR are you referring to the "Outdoor Fan" or "Condensor Fan" that circulates the air across the outdoor coil ??
If its the indoor fan on an air handler that's not running unless its in A/C mode, it will be a faulty heating circuit fan relay on the main control board.
If its the outdoor fan and its a heat pump system the outdoor fan stops during the defrost mode so there is a slight possibility the system defrost board is faulty and stuck in defrost.
A little more information may help obtain a more specific answer.
Apr 14, 2015 | Heating & Cooling
Byant ac not blowing cold air
Check outdoor unit ,if the outdoor fan is spinning ,check if the compressor is coming on , if both fan and compresseor are working
it may be low on refrigerant
Jul 01, 2014 | Bryant Heating & Cooling
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
The fan on my outdoor compresser unit has stopped working the motor is humming and the fan doesn't turn if you manually push the fan blades around the fan will spin but at a very slow speed. The unit was...
It could be either one or both...usually I like to do both at once because either one can cause the other to fail...that problem is a common one for air conditioning units...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 23, 2010 | Bryant 463AAC008BA Air Conditioner
The fan does not spin
If this unit is located outdoors then it is your condensor fan. Can you hear the compressor come on? If not it could be the capacitor is bad,
If compressor comes on but fan does not, it is most likely your fan.
Jun 26, 2010 | Ruud UAKB048 Air Conditioner
Compressure and fan not coming on, contactors pulled in from 24v .light blinks 3 times lps hps are jumped add freon still not working.
Sounds like your breaker is tripping for your outside unit. Compresser could be grounded out or a breaker problem.
Oct 08, 2009 | Haier HC48C1VAR Central Air Conditioner
Fan is not spinning on outdoor unit
There would be a control wiring problem.Either the fuse is blown out, fan motor may be burnt out and blade is loosened.
Aug 15, 2009 | GE AGP07LH Air Conditioner
Compressor motor run in high ampere and then shut off
Check compressor capacitor to see if it’s good then check the contactor points and see if they are burnt or discolored if so then replace and make sure no wires are loose or burnt, then check the condenser coil to see if it’s dirty. Check to make sure outdoor fan is running and at full speed, if not then check the fan capacitor,and with the power and unit off spin the fan blade to see if it spins freely, if not the bearings are bad in the motor and it needs to be replaced.
Apr 20, 2009 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
