Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW1 F-11 code right afer it starts
GHW9100LW1 F-11 code right afer it starts to fill.. reset many time then will run norm. What is wrong?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Cranks fine wont start
www.ask.com/mfg.name/make/model/error/code/p1000/
did you check the rotor cap, check points and condenser if you have 1,
solenoid, check the wiring that plugs into the alternator, check all ground clean of rust, dirt, grease, oil,
if you have carburetor system, this a float issue, not set right
I KNOW YOU SAID YOU HAD GOOD FUEL PRESSURE but what if the pressure is to high???????????????????
contact me for more info if these ideas dont work
Oct 02, 2015 | 2000 Ford Mustang
Cherokee will not start until i hold down on the gas as soon as i take foot off it dies immediatly
Might have to reset the codes on the computer. Take the + battery cable off the battery and reconnect it afer 5 minutes. Next try to start the engine without holding the gas petal down, it should start and run rought till the computer resets itself. If engine stops, restart the engine and hold the gas petal down and give it enought gas so it will run smooth, it may take 5 minutes or so for it to smooth out and run at idle speed. If this did not fix the problem, check for a vaccum hose that may be off some where on the engine
Sep 05, 2011 | 2000 Jeep Cherokee
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
I have a hard time starting my 04 Santa Fe after i fill up
it was running then you removed the gas cap to fill ( extremely dangerous practice with car running)
that indicates that there is a problem with the EVAP system.
run the fault codes ( what the dealers should have done first ) and check for the EVAP codes , purge vent or solenoid problems
Apr 02, 2017 | 2004 Hyundai Santa Fe
HELP...1987 944 wont start afer replacing timing belt
Hi, You need to get your timing belt checked. Dont attempt to start the engine until your timing pullys are reset because if your cam is set wrong it WILL cause valve damage.If it is allready correctly set then i suggest you test the compresion in case damage was caused when belt was fitted. Hope all works out ok 4 you.All the best.Phil
Sep 10, 2008 | 1987 Porsche 944
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
