Question about Whirlpool Refrigerators
I have a Whirlpool ED20ZX fridge. It currently does not have an icemaker. I have a working icemaker in a Kenmore 57282791. Can I place the icemaker from the Kenmore into the Whirlpool? The parts look almost the same on RepairClinic.com site. Thank you.
  • 2,272 Answers
Yes both the parts look near to similar.But actually the voltages are different in both the parts.And also its not the exact same part.So it will not fit directly.But in case you get it any how fitted.Then also due to Kenmore voltage is higher then whirlpool. But still get both this parts checked by a refrigerator technician and ask him to confirm the voltage .And if its risky then ask him to connect voltage control resistor or in to the ice-maker circuit so you can get it connected without any voltage issues. Also to confirm first remove both the ice-makers from the unit.At the back side of the unit there is voltage and current description mentioned.Check out that.If its exact same then you can go for replacement.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 12, 2010
How will an icemaker from whirlpool $ET1CHMXKQO4 WORK IN Kenmore 5********** ?
Need the model number to answer that question Kemore is a brand name not a manufacturer.
Oct 05, 2015 | Kenmore Refrigerators
I have a Kenmore Coldspot m# 57282791. Last night, it stopped staying cold, and I have not heard the motor/compressor come on at all since then (the part that cools the fridge, right?) There is a small fan...
If the compressor is not running, it could be either a bad relay or compressor.This is not an issue with defrost components or temp. control .If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Kenmore 57029 Side by Side Refrigerator
My whirlpool ice maker makes ice but it builds an ice dam and ice cicles on the back of the unit.
there might be a crack in the mold of the icemaker. you can unplug the fridge and take out the icemaker. there should be three 1/4" screws holding it in place. visually inspect the icemaker mold the see if its cracked or flaking. if it is, the icemaker needs replacing. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge won't make ice
There is an optics test procedure you can perform on your own to confirm what the repairman says. Assuming you have a whirlpool-made Kenmore (if you have a Pur water filter at the bttom left of your unit, you do), see here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Basically, the icemaker won't initiate a harvest (dump) cycle unless the electric eye through that cutout at the top of your icemaker can see across the top of the dispenser. If the lens is dirty, or if either the emitter or receiver boards are bad, the optics won't connect. There's a simple diagnosis procedure in that pdf above. Since your fridge is from 2005 like mine, refer to the "post 2002 redesign" optics procedure. Basically the test is to open the fridge and look at the LED, then to close the flapper on the left wall of the freezer and see the change in LED behavior. This can confirm or deny an optics issue. Also, if you remove the little plastic grille at the bottom of your fridge, there'll be a piece of paper folded and stuffed in there with the diagnostic procedure in it as well. To do the full diagnostic procedure, you'll need to remove the icemaker and install a jumper, but to debug optics only, all you need to do is open the door, close the flapper, or maybe push in the door switch and look at how the LED responds.
Mar 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side-by-side fridge icemaker
yes. replace the icemaker modual and your problem is solved
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
