Question about Acer TravelMate 290 Notebook
It won't boot the hard drive, yet it still shows it is present using a boot cd. Is there any setting i should check?
    Guru:
  • 551 Answers
Its like this, the board of the Hard Drive is working but the disk or the reader of the disk maybe not working that's why it shows on the boot cd. My suggestion is to replace the hard drive the start a new installation.
Posted on Jul 12, 2010
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
Hard drive won't reboot (jumpers not set proper)
Just google your drive's make and model and search the results for a diagram of the jumper settings.
If you have a SATA drive, there ARE no jumpers. If the drive is a PATA, then if it's connected with another drive or cdrom, then make the cdrom 'slave' and the disk drive 'master'.
Check your bios setting sometimes bios changes the boot order esp. if bios doesn't find a boot disk- make sure you have your desired boot device showing in the boot setup.
Oct 31, 2012 | Hitachi Computers & Internet
With new blank HDD,recovery cd in place,states no bootable device
Does the hard drive show up on your boot order? because if no detection is indicated that would explain why it is not working. Check out my computer to see if C Drive is present, check device manager that it is enabled.
Jun 17, 2012 | Dell Inspiron 8200 Notebook
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
Won't boot from hard drive
Check the boot settings. The bios may be trying to boot the old hard drive and doesn't even see the new one. If the old hard drive was removed, the BIOS will go to the next boot device. Also, is there something on the hard drive to boot to? If it is a blank hard drive you will need to install an operating system, otherwise it will not boot.
Feb 25, 2010 | Toshiba Computers & Internet
I have a toshiba p205d-s7436 when you turn the laptop on a black sceen reads toshiba leading innovation i tryed putting recovery discs in will not reboot tryed f12 and f2 it will not boot up PLEASE ANY...
The first step is to check the BIOS to see if your hard drive is listed. If so, is it set to be the first boot device. To enter the BIOS, use the F2 option when prompted.
If the hard drive is not present, it's either come loose, or the drive's controller has failed.
Also, if you can use the F12 option to boot to a CD/DVD drive, use another computer to download the Ultimate Boot CD iso from http://ultimatebootcd.com, and then burn it to a CD. This will create a bootable diagnostic CD that you can use to run diagnostics of your hard drive.
Let me know how this works for you.
Sincerely,
James O'Brien
Oct 04, 2009 | Toshiba Computers & Internet
Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
Aug 18, 2009 | Computers & Internet
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Acer TravelMate 290 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
