Question about Cyberhome DVR 1600 DVD Recorder
DVD-R formatting fails
DVD-R formatting hangs momentarily at 49% complete. Then hangs at 98% complete. After about 15 minutes, disk error message displays. DVD-R is Memorex 16X. Tried 2 other new disks and failed same.
    Genius:
  • 1,234 Answers
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 28, 2010
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Nokia n95 8gb disk error problem
dear, there is a 8gb hard drive in ur phone now its gvng u disk error.to sort out this u have to format ur phone hard drive because a bad sector has been formed due to overloading or virus which can be removed by formatting
Jul 03, 2009 | Nokia N95 Cellular Phone
Windows XP with SONY RW-AW-G170A DVD Rewriter.Unable to format UDF on DVD disc even after disabling-in built CD burning engine.Formatting starts fine but after afew minutes alert message appears:...
THIS PROBLEM SEEMS TO NOT UR DRIVE BUT
1. WITH UR SOFTWARE OR
2. THE DISK U R USING
MAX TIMES THE DISK CAN NOT FORMAT SO 1st TRY TO CHANGE THE DISK
I THINK THIS WORKS
PLEASE VOTE FOR ME
May 19, 2009 | Microsoft Windows XP Professional
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Get a "fail" error message when trying to record dvd
check disc speed some dvds don't like under 8x
have you got manual , what type disc are you using ? still need help call 0403960527 jeff
email jcshepard55@hotmail.com
Feb 16, 2009 | GoVideo Go Video DVD/VCR Combo
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Dec 21, 2007 | Optical Coating Model 108 VHS VCR
Cyberhome DVR 1600 DVD Recorder Logo
87 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
