Question about Briggs & Stratton Garden
Briggs and stratton 4.5 hp ( 10G902 ) starts great but after a couple seconds starts to stumble. i have replaced the plug, gas and cleaned the air filter. I tried a couple things like spraying carb cleaner in the ''carb'' opening, waiting 15 minutes then poking a bread bag tie into the small hole. no luck getting the stumbling to go away. it was running fine when this started during a mowing episode. any help would be greatly appreciated, thanks
  • 755 Answers
Try draining the carb and gas tank into a small plastic bowl and look for water in the fuel. I you have a diaphragm type carb it might just need a new diaphragm and spring.
Did the stumble start right after refueling? If so then your gas can may be carrying some water too. It happens. I have seen gas can with INCHES of water in the bottom! True story. I went to a customers house after she had both her walk behind and rider stop running. She said both were fine until she refueled and then...no start. I looked at her gas can and it was terrible!
If you are trying to clear the main jet you need to get inside the carb and clean from the fuel inlet side. Bowl carbs usually have removeable jets that you can look through.
Good luck and be careful!
Posted on Jul 13, 2010
  • 6 more comments
  • qwkstng Jul 13, 2010
    Thank you for your time in responding!
    it started about 45 minutes into mowing and i hadnt refueled. i had tried draining the fuel tank. I could not get it completely drained but i did use fresh gas when i refueled and tried again.
    yesterday i completely tore the whole fuel tank, carb and plastic (grey) cross tube apart and cleaned everything. i didnt see anything wrong with any of it ... but it started and ran like it should for 5 minutes ... so i am assuming that its fixed. i did completely drain the fuel tank this time.
    thank you again for your time!
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton engine stumble
Hello there:
first i would shorten the gap on the plug and if needed readjust the air/fuel mixture as per specifications
Sep 15, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
497 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
