Question about Amana ACF3325 Gas Kitchen Range
When I use the oven we can smell gas in the house. It has just begun to do that - we have had the oven for about 14 years
  • Amana Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jul 16, 2010
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
I turn the oven and it gets warm but not hot and I smell gas
Warranty Information
Contact information
800•944•9044
Electrolux Home Products North America
P.O. Box 212378
Augusta, GA 30917
- WHAT TO DO IF YOU SMELL GAS:
• Do not try to light any appliance.
• Do not touch any electrical switch; do not use any
phone in your building.
• Immediately call your gas supplier from a
neighbor's phone. Follow the gas supplier's
instructions.
• If you cannot reach your gas supplier, call the fire
department.
- Installation and service must be performed by a
qualified installer, servicer or the gas supplier.
Dec 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
I can't find the pilot light shut off valve on my Magic Chef oven. Where is the gas shut off valve? It is 20 years old, uni burners with self cleaning oven. 314-837-1073
Good chance there is no shut off for the pilot by its self. Of course one should have been installed at the back where the line comes into the house. If you are smelling gas please turn off your gas until you find the problem.
Aug 16, 2010 | Ovens
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Apr 06, 2009 | Frigidaire FGF378AC Gas Kitchen Range
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
Constant gas smell. had PG&E come and check. The determined the leak is coming from the stove somewhere, not from the gas line
i have a 2 year old stove, and i smell the gas every time i walk by it, i when on a mission to find it, and it was coming from the safety valve in side the oven, right where the burner sits on. open the oven door when all the house doors and windows are close and smell it and check if is coming from the in side of the oven, not all gas leaks are from the same place, that's like a hands on job, to find a gas leak. you can also check every valve with some soupy water this are the ones that suplie gas to the burners.
Dec 05, 2008 | Viking Kitchen Ranges
Gas Smess
the gas might be too high, try turnin it down, or their is a falt with the oven
Jan 13, 2008 | Ovens
Open Questions:
Amana ACF3325 Gas Kitchen Range Logo
163 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
