Question about GE Dishwashers
We have standing water in our GE monogram dishwasher at the end of the cycle. I checked the hose and there is no blockage. Would a reset help this? Do I need to contact a technician? Any help would be appreciated. Thanks!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dont think reset will help as dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. As you have already checked the drain hose for clogs and it is clean then it seems that the issue is that the drain pump isn’t working correctly. Also check any clogs in the drain pump and filter, if they are fine then you’ll have to replace the drain pump. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
GE model #GSD5130D00WW Dishwasher leaves standing
There is a valve in the rear of the machine under the screen. If it is worn will not drain well . unscrew the valve and check whether the rubber cone is still all there. run in pump cycle with the valve out to clean the unit out.
Dec 03, 2010 | Maytag Dishwasher
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Standing water
I would say you have a clogged drain hose. Check the hose for any blockage. Also may need to check under the dishwasher where the drain hose connects to the washer - this is where i've had blockage before. Make sure the power is off to the machine, as the wiring is around that area also.
Mar 04, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
Dishwashers Logo
29 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
