Question about Panasonic Lumix DMC-FZ10 Digital Camera
The telephoto to wide angle range only goes half way (from mid to telephoto only). What can be done? Thank you! The camera has not been dropped but we do live in a tropical environment- we do keep the camera cool and air conditioned when not outside. All other functions work great.
  • forbidden_is Jul 12, 2010
    I really appreciate the advice above, however the problem persists. There are no error messages it's just that the lens will not go all the way to wide angle (gets stuck about a little less than half way mark towards the wide angle side. I feel like there is a piece of grit keeping it from working but can not get it to move... Thanks again for your help!!! Any other suggestions? Randy
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 12, 2010
Testimonial: "Although the camera still refuses to cooperate, I really appreciate the prompt and thorough suggestions to solving this problem with the Lumix FZ-10. Thank you so much!!!"
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
I am having trouble photographing birds. Do I use the telephoto lens or the wide angle lens? I also have a macro lens for my Canon EOS 400D SLR Also what settings do I take them at. I have a tripod but the...
Use the telephoto lens.. wide angle will tend to distort the image and provide too much detail( distraction) around the object of interest. Bird pictures become more interesting when they are mainly of the bird. So when you look through the lens, zoom up to the bird to the point where you have it nicely framed with none of its parts outside of the frame.
Capture the whole image.
Wide angle lens is mainly used for scenery or where you want to take a group photo or panorama.
Please rate my help++++Thanks for using FIXYA
Nov 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
How to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
Nov 12, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Sony handycam CCD-TRV318 NTSC Telephoto/wide
Tele-wide switch is fauly.(technical name is SWITCH BLOCK CONTROL).repalace by expert.
Jun 20, 2009 | Sony Handycam CCD-TRV318 Camcorder
Dropped my camera bag & my 17-55mm Lens Now will not telephoto
The best way to get it done right after you drop the lense is send it to NIKON NY . They put the lense on a resolution bench test and it make sure the resolution is great ,. This lense is very criticial and it is a must or your wasting your money . The reason is this ., The lense is a wide angle and sometimes photographers have probelms with 17-55mm lenses and sub mirror problems . So its best to be safe than sorry .
Mar 07, 2009 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Focusing range of the DiMAGE E223?
The DiMAGE E223 is capable of focusing on subjects within the range of approximately 60cm to infinity at both wide-angle and telephoto.
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
How can I get the firmware for utilizing the telephoto converter / wide-angle converter
The firmware for telephoto converter/ wide-angle converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. DiMAGE A200 users do not need the firmware updating.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
Telephoto and wide angle lenses
Yes, you can use different lenses with the PhotoPC. To find out what lenses are compatible with the PhotoPC, contact TIFFEN.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Shutter lag
we're talking milliseconds... my camera takes the picture when i press the trigger and sometimes its so fast that accidentally take the picture before i have focus lock (that my error not the cameras, i just get trigger happy sometimes)
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
98 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
