Loud fan noise
My window unit has just started making a loud noise which sounds like it is caused by the fan. Is there an at-home fix or do I have to buy another unit?
Replace the fan or replace the unit
Posted on Jul 12, 2010
Dehumidifier started making a loud noise. Is this something we can fix?
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Jul 27, 2015 | Midea Westpointe 50 Pint Dehumidifier
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
