My internet globe light is blinking and the wireless is not working.
  • 6 Answers
SOURCE: The light with the globe is constantly blinking
If you tell me the version number of your Belkin mimo wireless router , i will fix this issue.Any Routers issue contactme,, i will help you out. copy and paste this URL to your Browser http://techhobbies.blogspot.com
Posted on Mar 05, 2009
  • 145 Answers
SOURCE: blinking lights on Belkin router
They will blink as long as their is internet activity from the modem.
Posted on May 28, 2009
govinda123
  • 2268 Answers
SOURCE: Globe light blinking! no connection?
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Posted on Jan 16, 2010
  • 116 Answers
SOURCE: cannot connect to internet
If the modem light is blinking it means that there is activity, so this is normal.
However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type 192.168.2.1 in the address bar.
By default the password should be left empty.
Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
I hope this helps!
Posted on Mar 02, 2010
puertobori
  • 7733 Answers
SOURCE: The WGT624 v3 internet globe
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Posted on Nov 13, 2010
My dlink router dir-600 was purchased only last month. It was all working well until 3 days ago...the light in wireless icon and other LAN all stopped. Only power and Globe lights were Orange... no...
If you have ethernet cable, plug one end of cable into in available slot of router (LAN) and other end ont your laptop to see if you can get out Internet that way. If not, turn off you router, wait for a minute and turn it back on. If it works after the reboot, try wireless again to see if it works. Most of time, router just needs to be rebooted.
thanks
May 13, 2011 | D-Link DIR-615 Wireless Router
Our wireless devices, IPOD and laptops, will not connect to the internet. It is not even showing Linksys available to us. The wireless router is hooked up. The #1 light (ethernet) keeps blinking on the...
If by "reset", you mean you have done a factory defaults reset by pressing and holding the RESET button down for 15 to 20 seconds, then it sounds like your router has failed.
If you haven't held down the RESET button on the back for 15 to 20 seconds, then try that. If that doesn't return the router to working order, then the device is defective.
You should be able to get a warranty replacement.
Dec 30, 2010 | Linksys WRT120N Router
Cannot connect to internet. router modem and globe lights blinking amber.
I hope this helps!
Mar 01, 2010 | Belkin (F5D5231-4) Router
without the CD.
through the modem
ISP.
Jan 16, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My laptop is connected but can't get on the internet. The modem light on the router is blinking orange. The globe is not lit at all. It worked fine for about 4 months until yesterday. I have unplugged both...
go to my connection and check if the wireless was available or connected, if not availale, that means some files of the driver are corrupted. Run your recovery disk.
Nov 22, 2009 | Belkin F5D8236-4 Router
Blinking lights on Belkin router
May 28, 2009 | Belkin (F5D7230-4) Router (587009)
Feb 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Pc works via ethernet cable but wireless laptop cannot see the network
I think you have lost your PPPOE internet connection. Reestablish the connection. If this is not the problem, click your wireless connection on the taskbar and search for your wireless device and reconnect. BPCS
Dec 29, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
158 people viewed this question
Alun Cox
David Payne
David Payne
