Question about Boating
My RPM's are norman and even higher but I'm down about 10 mph.
How to change a Berkeley jet pump impeller?
I own a 20 foot jet boat with a 455 cubic inch Oldsmobile engine. My engine's RPM's are norman (and even higher) but I'm down about 10 mph from 52 mph to 42-45 mph. I believe it may be my impeller that is starting to wear out.
  • 677 Answers
This is a shot in the dark BUT check to see if there is a wear ring that would sit around the outside of the impeller.Its inside the pump but would be right where the impeller spins.Jet skis have them and I thought yours may also.Hope this helps
Posted on Jul 12, 2010
2011 seadoo boat 150 speedster surging up and down on full throutle but idles fine in neutral and changed the plugs and new gas and tps sensor and still no differnce
Check for air leaks on the manifold, or fuel air locks, fuel starvation. Tank vent, kinked pipes, that sort of thing.
There is further help in the link.
This is caused by minor cavitation. It is not an actual issue. What is happening is that your impeller is moving fast enough that it's drawing out the available supply of water since the boat is moving slowly and there isn't enough pressure on the bottom of the boat the keep the jet pump fed with the amount of water you're expelling out the nozzle. Water is fed into the tunnel in the transom by the pressure caused by forward motion at speed.
Every jet boat will probably do it at a certain RPM depending on many different factors even down to water temperature, fresh/salt water etc.
For the longevity of your wear ring and impeller...avoid that rpm.
2011 seadoo boat 150 speedster surging up and down on full throutle Google...
Aug 14, 2017 | Cars & Trucks
How deep water for pump 63407
you have to say what pump you are using
if it is a submersible pump it could be jammed impeller blades and a blown circuit breaker
if it is a centrifugal pump and is not a jet assist pump then the lift head is exceeded to lift water to the pump from suction Most pumps of this type have a max head lift of 10 ft with a 2" suction pipe as the weight of water is too much to lift A jet assist pump is a better option for up to 20 ft
next is the pump primed now if it was pumping before as a bad foot valve will leak the water out of the pump so that it requires priming before it will work
Jul 13, 2017 | Plumbing
What is a boat impeller?
on jet boats
jet engine for the water sucks in and pumps out water very high pressure to give forward motion
Motovated Design and Analysis Superboat Impeller Animation
Oct 07, 2016 | Garden
How do I remove an impellar from a 2002 sea doo GTI LE ?
You need to have the Impeller removal tool. I found one on ebay at the following link: http://www.ebay.com/itm/SeaDoo-Kawasaki-PWC-Jet-Boat-Jet-Pump-Repair-Impeller-Removal-Wrench-Tool-/390828336861
I found a great start to finish rebuild of your impeller on you-tube. Its a 5 part video. Click the link I provided and scroll down to the impeller videos. http://www.youtube.com/channel/UC8ecHS-HG-eQpel1r-DZnuw
Here is a link for schematic and parts list of your jet pump: http://www.seadoopartshouse.com/oemparts/a/sea/500d79f2f8700209082580e0/propulsion-system
If you are replacing the impeller, here is a page of what.. IF anything you can do as far as performance improvements: http://www.pwctoday.com/showthread.php?t=309226
The stock specs for your impeller are dual pitch 9 / 20 and 155mm diameter.
Jul 14, 2014 | Sport & Outdoor - Others
How far will a 1 HP jet pump jet.will it jet at 125feet.if so how much gpm and what size jet do I need
That is quite a large distance to pump for most electric pumps. We had a gas 8-10 HP firepump which was used to pump out of several 6" steel cased drilled wells on a ranch. It was a KUBOTA with high performance " high head" design which gave both lots of water for fire control and the ability to do the work of raising water a long way up a hill if needed. The clearance between the impeller and the case needs to be very small so expensive machining is involved, possibly even "Crane" seals with spring loading and sliding nitrite discs instead of just a bronze bushing in a so-so aluminum casting. All pumps will have specs for GPM but they shy away from giving you a graph of GPM versus Pump Head at those 125 foot amounts, the KUBOTA states the chart right away since it is a very high GPM pump in those high water lift conditions. Residential jet pumps just build designs for a lift of 40 feet or less so they might even stall out at half of your requirements. You might even think of the old DURO pumps from CANADA with a 1/3 HP GE motor and use two pump houses with electric power and small 20 gallon steel pressure tanks to relay the water in three steps from the source. I purchased two of them for rebuild for $50 and you can fix them up easily using Generic Chinese piston pump parts which are an almost exact fit copy of the DURO.
Jun 04, 2011 | Hardware & Accessories
No Power at Takeoff
If the trans runs at 20 mph with a rpm factor of 3000 plus yes the trans is shot
May 31, 2010 | 1994 Chevrolet S-10
I have new 40hp mecury lightining my problem is when i take off feels slugish and does not take off like two stroke should. i was told its the set size origional at 0.80 should be at 0.85 is this the...
I'm assuming that you mispelled and set should be jet. I'm also assuming that you're at a higher altitude. That could mean changing jet would improve performance. Changing your original propeller which was designed for sea level could also help. I know that my 115 horse Merc could only get up to 4200 rpm with the factory prop that was 17 degree prop. I changed to a 15 degree and got to 5200 rpm and a 13 degree got me to 6000 rpm. It's a little expensive but to get to optimal performance for your motor you'll probably need to change jets and prop.
Nov 12, 2009 | Light Outboard Motor Boat Bass Fishing...
The RPM of Nissan Altima stays high when drive over 65 MPH.
No....the rpms differ from engine to engine and from manufacturer to manufacturer. RPM's are always higher at higher speeds.
Aug 25, 2009 | 2002 Nissan Altima
Loss of speed. ..upon acceleration over approx 25/30
If you are achieving proper max RPM but not achieving peak MPH, the prop is cavatating. That means it is aerating the water around the impeller. The most common cause of this is debris (rope, weeds) wrapped around the prop shaft. With the lanyard key in your pocket, look up the intake screen for the jet pump and see what is wrapped around the prop shaft. Once you remove that, your MPH should be right back to where it was.
Jul 12, 2009 | Yamaha 12V Air Pump
Loss of speed
Try having the carbs cleaned.
Jul 03, 2009 | Yamaha 12V Air Pump
Boating Logo
145 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
