Question about White Hall Hudson Bugwiser 2-Gallon Multi-Purpose Sprayer #65222
Parts for a ortho 2 gal. Multipurpose sprayer. The trigger housing has frozen this past winter and now leaks
Ortho defense sprayer
The battery installation diagram is molded into the battery compartment. The compartment is poorly designed, allowing battery disgorgement at inconvenient times.
Jul 26, 2016 | Ortho Home Defense Max Insect Killer 133...
Home defense continuous sprayer won't spray. I have replaced the batteries.
Had the same problem with other maker product. See if this helps. I found that chemical from earlier use locked the pump up. I took it apart and cleared the blockage in the hose.
May 26, 2014 | Ortho Home Defense Max Insect Killer 133...
Ortho home defense comfort wand won't spray
I called Ortho and they did not want to send me a new sprayer. They told me to take pliers and remove the nozzle then soak in warm water. They also suggested I hold at shoulder height and spray directly to the ground for 30 seconds.
Sep 04, 2013 | Ortho Home Defense Max Insect Killer 133...
I am looking for the tube inside an ortho 2 gal plastic sprayer. It is plastic and broke. Just a straight plastic tube with a slightly flanged top to fit in the sprayer.
I am sorry for the problems you are experiencing with your Tank Sprayer. Please give us a call at 877-465-5160. Hilary @ Ortho
Aug 12, 2011 | Garden
Just brought new ortho spray home from lowes. followed all directions and it will not spray. not very happy!
I am sorry to hear about the problems you are experiencing with your sprayer. We do have replacement sprayers available. Please give Ortho a call at 800-225-2883. Hilary @ Ortho
Jun 18, 2011 | Ortho Home Defense Max Insect Killer 133...
My 2 gal yellow ortho lawn sprayer will not get pressure to spray when I pump it. What can I do to resolve the issue?
First Check the gasket around the lid, and the one around the pump housing for any kind of leaks. If this does not solve the the problem, check the sprayer to be sure it is not on all the time you are pumping.
After that you may need to invest in a new sprayer.
May 08, 2011 | Garden
I have a 2 gal ortho heavy duty pump sprayer and I'm need a new nozzel. Where can I find replacement parts?
I guess a company called the Fountainhead Group makes a lot of different sprayers other companies. They have repair parts available on their site. I replaced the nozzle and installed fresh gaskets with a kit from Lowes and with info from this site; http://www.creativeworksforchildren.com/how-to-repair-ortho-roundup-garden-pump-sprayer.htm
Aug 03, 2010 | Garden
I'm looking for a replacement part--the trigger for the handle
Did you ever find a place to buy replacement parts? I need one too
May 12, 2009 | Ortho Garden
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
White Hall Hudson Bugwiser 2-Gallon Multi-Purpose Sprayer #65222 Logo
364 people viewed this question
Top White Hall Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a White Hall Garden Expert? Answer questions, earn points and help others
