Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE profile, sensor microwave oven will not turn on. How do i fix it?
How do i turn it on
Posted on Feb 26, 2011
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
My GE Profile JE1390 (Sensor Convection Microwave Oven) is coming on when the door is opened. It will still work once you put food inside and set the timer, but you risk radiating yourself. What might...
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 19, 2011 | GE JE1390 Microwave Oven
Have a GE "Spacemaker II Sensor" microwave oven. When we try to cook now, it trys but the food does not get hot. Something is getting hot becasue there is a distinctive smell, perhaps like a burnt IC or...
you will need to find the source of the burning. it could be a cheap fix or more involved depending on the component. it could be a transformer, h.v.diode, magnetron, etc. if the diode is shorted, there is a good chance magnetron is defective too.
Aug 31, 2010 | GE Profile Spacemaker II PEM31 Microwave...
My ge Profile microwave oven will not heat! It turns on but doesn't heat... Any idea?
I had the same problem. I fixed it by replacing the primary (upper) door switch. The switch is about $50 from repairclinic, but it beats scrapping the whole oven. Tips: - If you don't have a torxx screwdriver, you can use a regular small flat screwdriver that you wedge between the torxx pin and the side grooves. - When tested standalone with an ohmmeter, the switch seemed to be healthy, but when you press on the pin a bit more it fails. I guess cycling the door eventually damages the switch.
May 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
GE Profile Sensor Microwave Oven model JE1660
heatman101
yettu
Sep 07, 2008 | GE JE1540 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
348 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
