Question about Whirlpool Duet GHW9150P Front Load Washer
Clean pump message coming up clean pump, How do you clean pump?
  • 5,911 Answers
If this is a Whirlpool Duet model washer, the following link explains step-by-step, how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If this is not the model washer you have, or if you require additional assistance, please post back and let me know. I hope this is helpful to you.
Posted on Jul 12, 2010
We have a hot point aqgmd149. It came up with the machine is blocked. We followed the instructions to clean out the pre filter but it still won't do anything itvkeeps coming up with the same error message!...
are you talking about the drain pump?if so if you cleaned out the pump and hoses and it still won't drain you have a bad pump,you have to replace the drain pump if error code keeps coming up
Dec 15, 2014 | Washing Machines
Laser 73 got ee 2 message. Cleaned the filters. Plenty of fuel coming into the pump. When the pump comes on it begins ticking. Took off the line going into the chamber while pump was running/ticking and...
Here is the copy and past explanation from the troubleshooting page on the manufacturer web page:
EE2 Failure During Ignition.
Dirty flame sensor.
No fuel to unit.
Poor contact on flame sensor wire. Defective flame sensor.
Defective igniter.
Plugged fuel nozzle.
Plugged or defective fuel sump.
Defective high limit switch.
Defective circuit board(s).
Oct 10, 2014 | Heating & Cooling
Ld Message
Hi
An LD error indicates long drain time which means that there is either something stuck/clogged in the pump or the pump itself has gone bad and should be replaced. You can take it apart completely and check for impeller damage or clogs. You have to clean it completely so make sure that you have lot of towels ready as there will be water coming out of it when you clean the pump. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Kenmore 22422 Top Load Washer
Getting E20 error message so I need to clean out the pump and hose but I can't get inside the machine - how do I get access to the pump? Thanks
Try bottom right / drawer here Filter within, you will see a long tube that comes out ,you take out the end stopper and drain first then remove and /clean filter good luck...
Apr 01, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Oe message...filter is clean. water won't drain out. tub is ful
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Dec 21, 2009 | LG WM-2277HW Front Load Washer
Whirlpool A+A 5kg/1000 AWO/D4305 clean pipe light has come on what shall i do
I think you are wnting to tell the message is " clean pump ". There is no such " clean pipe ". Sir, please reply me for this matter.
Sep 06, 2009 | Whirlpool Washing Machines
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
My kenmore elite top load washer displays a ld message how do I fix ?
You need to clean the pump by removing the bottom panel via 3 screws in the bottom. The pump clean out should be a plastic circular access door that rotates counter clock wise. Warning , water is going to come out when opened, so be ready. Remove any debris from in the pump, reassemble and give it a try. Hope t his helps. www.washermd.com
Mar 03, 2009 | Kenmore Washing Machines
F-05 flashes up and water not draining out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Jun 30, 2008 | Hotpoint Aquarius WD640 Front Load...
Pump blocked message
next time u clean the filter when it is empty of water. put your finger in the whole and u will find somthing wound round the impeler of the pump remove what ever is obstructing and u will have no more problems make sure u unplug the machine b4 you start doing this good luck
Sep 03, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
139 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
